i migrated my home assistant to a SSD, and used a snapshot i made just before that to restore it.
Its running on a pi4 which is connected via ethernet, and i use a windows 10 pc to interact with it.
Before the snapshot it all worked perfectly but now no longer.
Duckdns also stopped working but i fixed that by making a new domain name. Esphome also stopped working but a re-install fixed that. But now samba share is refusing to work even after a re-install. My pi also doesnt show up on my network either but other devices do.
The log shows the following:
INTERNAL ERROR: open_sockets_smbd() failed in pid 32801 (4.13.8)
If you are running a recent Samba version, and if you think this problem is not yet fixed in the latest versions, please consider reporting this bug, see https://wiki.samba.org/index.php/Bug_Reporting
PANIC (pid 32801): open_sockets_smbd() failed in 4.13.8
unable to produce a stack trace on this platform
coredump is handled by helper binary specified at /proc/sys/kernel/core_pattern
smbd version 4.13.8 started.
Copyright Andrew Tridgell and the Samba Team 1992-2020
Registered MSG_REQ_POOL_USAGE
Registered MSG_REQ_DMALLOC_MARK and LOG_CHANGED
Processing section "[config]"
Processing section "[addons]"
Processing section "[ssl]"
Processing section "[share]"
Processing section "[backup]"
Processing section "[media]"
interpret_interface: Can't find address for eth0
WARNING: no network interfaces found
INFO: Profiling support unavailable in this build.
No builtin backend found, trying to load plugin
daemon_ready: daemon 'smbd' finished starting up and ready to serve connections
open_sockets_smbd: No sockets available to bind to.
Does anyone experience the same, or ran into this issue aswell?
any input would be appreciated
