I want to migrate all to one nuc box
I have right now on seceral pi’s hassio, lms, rhasspy. I also have aeotec z stick attached and want to add a dvb-t2 to watch live tv.
Is it possible to run all on the same nuc?
Any recommendation which nuc or other htpc?
I want to be able to add more things in the future like cameras or so.
any NUC will be far superior to an RPI…
just make snapshot on the primary and then deploy to nuc once you hace the image built.
I would then look at either making a backup of the other applications or simply reconfigure on the NUC…
I know nuc is far better than rpi.
the question is if any nuc is enough for my needs: hassio, lms, rhasspy (voice assistant), aeotec z stick and dvb-t2 stick attached?
does gen 8 i5 with 8GB has plenty of place to grow with future needs?
Is nuc the best or are there other mini pc’s that are recommended?
eaxch individual is different. you will need to spec it yourself, as well as your roadmap. but any NUC should be able to handle everything you have mentioned
