Hey All,
I’ve been seeing a lot of threads with older information and I was curious now that we’re in Jan of 2024, is there now a better way to migrate from a 500 series stick to 800 or is it just a very manual process?
freshcoast
(Z-Wave AI Bot)
January 16, 2024, 10:15pm
2
No, it’s still a manual process and that won’t change until after the Z-Wave JS maintainer returns from leave in April 2024.
There are some bugs in the latest 700/800 series firmware. I would not migrate at this point if your current network is stable.
opened 12:01AM - 20 Nov 23 UTC
integration: zwave_js
### The problem
I am commonly seeing my USB device (Aeotec Z-Stick 7 Plus) repo… rt being "Jammed" and then shortly after report being "Ready." Around this time, any operations will fail to occur and the system does not go back and "recover" from missed actions / automations.
### What version of Home Assistant Core has the issue?
## System Information version | core-2023.11.2 -- | -- installation_type | Home Assistant OS dev | false hassio | true docker | true user | root virtualenv | false python_version | 3.11.6 os_name | Linux os_version | 6.1.59 arch | x86_64 timezone | America/New_York config_dir | /config <details><summary>Home Assistant Cloud</summary> logged_in | false -- | -- can_reach_cert_server | ok can_reach_cloud_auth | ok can_reach_cloud | ok </details> <details><summary>Home Assistant Supervisor</summary> host_os | Home Assistant OS 11.1 -- | -- update_channel | stable supervisor_version | supervisor-2023.11.3 agent_version | 1.6.0 docker_version | 24.0.6 disk_total | 228.5 GB disk_used | 6.1 GB healthy | true supported | true board | generic-x86-64 supervisor_api | ok version_api | ok installed_addons | Z-Wave JS (0.3.0), Let's Encrypt (4.12.9), Z-Wave JS UI (3.0.2) </details> <details><summary>Dashboards</summary> dashboards | 2 -- | -- resources | 0 views | 1 mode | storage </details> <details><summary>Recorder</summary> oldest_recorder_run | November 10, 2023 at 7:57 PM -- | -- current_recorder_run | November 16, 2023 at 3:32 PM estimated_db_size | 60.77 MiB database_engine | sqlite database_version | 3.41.2 </details>
### What was the last working version of Home Assistant Core?
_No response_
### What type of installation are you running?
Home Assistant OS
### Integration causing the issue
zwave-js
### Link to integration documentation on our website
_No response_
### Diagnostics information
[zwave_js-6d4b40be1e77c3e33d78bdf24d66a9c3-USB Controller-d288fb52eab027710676687815136717.json (1).txt](https://github.com/home-assistant/core/files/13405010/zwave_js-6d4b40be1e77c3e33d78bdf24d66a9c3-USB.Controller-d288fb52eab027710676687815136717.json.1.txt)
### Example YAML snippet
_No response_
### Anything in the logs that might be useful for us?
_No response_
### Additional information
I can provide debug logs if useful for zwave-js: Please let me know if you want an entire day's worth of info or if you would prefer a certain amount of time leading up to and then after an event.
