Dear all,
I newbie here with some questions. A couple of month ago I installed HA with Supervisor in a docker in my NAS Synology. I tried this option because I never worked with docker and I thought it was the easiest way to get addons and a complete snapshot of the system. I installed MariaDb and Influxdb because I’m monitoring my solar system and I’m interested in long term statistics. Later on I realized that this is not an officially supported installation and I want a stable system to run in a long term. I want to install a docker supported version in my Synology to avoid future issues. Now my questions (I was checking Migrating MariaDB from HassOS to Synology NAS ? Steps? - #11 by browetd, but didn’t clarify the issue):
I suppose that copying the configuration folder with subfolders in the new installation I will not lose my data but, as I have already MariaDb and InfluxDb configured and working, and assuming that I will install docker in the same NAS with the same IP, will HA work directly with such databases by default? In fact, Supervisor installed them as docker.
If not, is there an easy way to install MariaDb and InfluxDb in separate dockers and import the data already in the dockers installed by Supervisor?
In case I can keep the working databases, how should I update them if the new system will not have Supervisor?
And finally, is there docker version to install the snapshot system as implemented by Supervisor?
I have the option to install the HA in a VM, but my NAS doesn’t have enough memory and I’m checking the options to update it, but it will take several weeks / months, and I would like to have an stable system as soon as possible to avoid data loss.
Thank you very much in advance,
