I’m looking at migrating from Hubitat and am wondering how to create virtual devices, or replicate the end result. For a specific example I have a ZWave outlet that I use to control a space heater and a corresponding automation to allow me to turn it on, and keep it on via Google Assistant.
- Craft Room Heater - Outlet is the actual ZWave+ outlet, it is not exposed to Google
- Craft Room Heater is a virtual switch, it is exposed to Google
Here is the Hubitat rule:
The result/goal of the rule is:
- I can say “OK Google turn on the Craft Room heater” which results in Assistant turning on the virtual switch which triggers the rule to turn on the actual outlet
- After 30 minutes turn off the virtual switch, notify me that the heater is turning off in 1 minute, wait 1 minute, turn off the real outlet
- If I say “OK Google turn on the Craft Room heater” the virtual switch gets turned back on canceling the wait and resetting the 30 minute timer
- If I say “OK Google turn off the Craft Room heater” at any time, the actual outlet gets turned off and the whole wait gets cancelled.
The delay and notify I get how to do. I’m not sure how to emulate the virtual switch that turns off 1 minute before the real switch.
