The SSD did boot up once and I was able to log into a brand new HA-installation. Told it to backup from my latest backup/snapshot and that was it. Haven’t been able to get it working since. I’ve tried formatting the SSD again and doing the Imager-step once again. Still nothing.
My Pi works when booting from the sd-card.
When booting from the ssd, the first lines of the boot are:
net: no ethernet found
starting usb…
bus usb@7e9800000: usb dr_mode not found
usb dwc2
scanning bus usb@7e9800000 for devices… usb_new_device: cannot read configuration, smipping device 152d:0576
Is the formatting of the ssd that’s the cause? ve seen the same ssd used by others, so the model (hopefully) shouldn’t be the problem.
Depends on how recent the bootloader on your RPI3 is. For updating it, as described with the link I sent, you don’t need a wired keyboard. Just connect through SSH and do it over LAN.
Yup. Just install RaspberryOS on it, put it into your RPI3 and upgrade the bootloader.
Btw, if your Backup (Snapshot) is big better upload it to the RPI and restore from there after you have installed HA. This way seems to be more foolproof than doing the restore over the LAN.
Managed to ssh into my rpi and started to follow the checklist in your link. But when entering “sudo rpi-eeprom-update -d -a” I get an error stating that the command is only for Pi 4’s.
Plus, the software configuration tool has no “boot options” as the screens in the checklist does
The restore worked, except now me and Home Assistant no longer agree on what my user password was before the migration, so now I’m just brainstorming different passwords
already looked at a few of the suggestions, but trying to start again with the backup. Tried booting from the sd card again and I am able to login with the password I thought, weirdly enough.
At least it’s a learning experience!
