Because the zigbee2mqtt 1.18 addon sort of disappeared from the addon store, I decided to install the latest vesion of the addon to upgrade and clear the error.
This has resulted in none of my devices migrating across to the newer version of the addon, even though I have switched to YAML config edit mode and copied across the old working config. Any ideas what I need to do to get them to show up? I do use the shepherd/herdsman devices file as I have a device which (at least a couple of years ago) needed it to be supported in zigbee2mqttt…
Thank you
data_path: /share/zigbee2mqtt
external_converters: []
devices: devices.yaml
groups: groups.yaml
homeassistant: true
permit_join: false
mqtt:
base_topic: zigbee2mqtt
server: mqtt://homeassistant:1883
user: my_user
password: my_password
serial:
port: /dev/ttyACM0
advanced:
log_level: info
pan_id: 6754
channel: 11
network_key:
- [REDACTED]
- 3
- [REDACTED]
- 7
- [REDACTED]
- [REDACTED]
- [REDACTED]
- 15
- 0
- 2
- 4
- 6
- [REDACTED]
- 10
- 12
- [REDACTED]
availability_blocklist: []
availability_passlist: []
device_options: {}
blocklist: []
passlist: []
queue: {}
frontend:
port: 8099
experimental:
new_api: true
socat:
enabled: false
master: pty,raw,echo=0,link=/dev/ttyZ2M,mode=777
slave: tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5
options: "-d -d"
log: false
restartdelay: 1
initialdelay: 1
zigbee_shepherd_devices: true
zigbee_herdsman_debug: true
data_path: /config/zigbee2mqtt
socat:
enabled: false
master: pty,raw,echo=0,link=/tmp/ttyZ2M,mode=777
options: "-d -d"
log: false
mqtt:
user: my_user
serial:
port: /dev/ttyACM0
