I then used the steps outlined here to move all my devices over and rename them
Pay special attention to the instructions in the top guide as I was confused a bit.
There is a big difference between Z-Wave JS ADD-ON and the Z-Wave JS UI ADD-ON. Both of these can interact with the Z-Wave integration.
Both cannot be running at the same time. As long as you’re using only one at a time, they should operate the same way. I’m a fan of the Z-Wave JS UI as it gives some more options for adjusting settings but to each their own.
