Migrating SmartThings Motion Sensor
I’ve been using SmartThings for some years, and recently started moving to Home Assistant.
I’ve used the SmartThings integration, and everything has worked fine, except that I’m still dependent on a round trip to the internet to get the statuses into Home Assistant, so I’m trying to pair the devices directly to Home Assistant.
I have SmartThings Motion Sensors v1, which have connected perfectly. They show up as CentralLite 3325-S
I also have SmartThings Motion Sensors v2 , which connect.They show up as SmartThings motionv4. The temperature and battery level appear to be fine, but the motion sensor shows up as a simple binary switch, not a motion sensor. It does appear to be responding correctly, but is just sitting in the wrong domain.
How do I convince Home Assistant that it’s really a motion sensor?
Answering my own question: use a customization to set the device class to motion:
  customize:
    binary_sensor.zigbee_bathroom_motion_ias_zone:
      device_class: "motion"
I’d still like to know how to arrange this directly from ZHA, without needing the customization. But it’ll do.
Screen Shot 2021-12-27 at 8.29.50 PM
I have the same issue on 12.5 build, 12.6 build appear to be fine. I don’t have to do manual change using customize.yaml now.
FYI, i had to delete/ add 5 times for all entities to work.
Hi
I’m totally brand new to HA and I have a first gen Samsung smartthings sensor.
I’ve managed to get the sensor added via zigbee but I can’t seem to get it working.
It only says motion detected all the time and I’m a bit stumped.
Any pointers or steel by step instructions?
Many thanks
Old thread, but I’m digging up old hardware after moving over to HA.
My sts-irm-250 added just fine as-is under ZHA and I noticed the ‘iaszone’, but it Detected (motion) and Cleared (motion) just fine so all looked well. …except the motion continued to falsely detect and clear motion. I see the logs where this pattern continues through the night when the house is asleep. Naturally it will burn through a new battery in 2-3 days.
I tried the customization.yaml as @wimble mentioned, but no difference at all in experience. Anyone else have similar experiences with this old school motion detector?
ZHA reads mine as motion 5:
