I’ve been running HA OS on a RPi4b 2gb for a little more than a year and it has been good to me. During this time I had 1 sd card failure and have since moved everything to an SSD. It’s powered by poe and the switch that it is on has UPS backup.
Recently, I’ve been experimenting with HA on Docker for Mac and rather than restoring the current setup to it, I’ve been slowly migrating the different integrations over bit by bit. I gotta say, I’m fairly pleased (and proud of myself) with the progress of learning how to use Docker and things up with docker-compose. Much of all my add-ons that aren’t part of the unsupervised HA install are ~75% in place.
However, I’ve been a little turned off by the latest few setbacks which I can’t seem to work around. I’m not sure if I’m hitting the extent of being able to do this through docker on a Mac. Maybe it would work out better if it weren’t on the Mac OS and the reason I think maybe is that the “host” network mode is not available on Windows/Mac?
The two latest integrations that don’t seem to work thus far is AlarmDecoder and Sonos.
For alarm decoder, it seems I am able to connect to the host during the integration and it is able to allow me to configure alarm setting, door contacts and motion sensors. However, nothing is responsive: when walking in front of the sensors and opening doors, nothing updates. The “panel” card just stays “unknown” all the time. The integration also takes a VERY long time to “complete” after each restart. I don’t actually think it even finishes, but there are many lines of code in the log that seem to suggest that it has stopped responding correctly.
Sonos is unable to auto-discover even though the Mac is on the same vlan as the Sonos speakers. It actually isn’t just the Sonos speakers that doesn’t auto discover, but there are no auto discovered integrations at all. I didn’t mind manually setting up all the other integrations, but this problem with Sonos doesn’t seem to work even when manually pointing to all my speakers (which all have static IPs). When adding them all in manually, lots of errors pop up in the log.
I dread the day I have to deal with NGINX + DuckDN. Because of what I think the crux of the problem is, network mode, I feel that working through this would likely be a complete disaster. Who knows what else is waiting for me down the road with whatever integrations/add-ons.
If anyone has general comments or specific fixes for the above integrations, great, but I guess I’m trying to ask is, is this sort of configuration generally not used because there is inherently something amiss with the docker configuration on Windows/Mac?
The motivation for setting it up this way is to 1) repurpose older hardware and 2) being a laptop, it has inherent “battery backup” 3) the rpi4 setup for some odd reason for these past couple months exhibits very high memory usage and is causing some issues and so I thought I’d give this a go.
I think I can foresee suggestions to run docker some other way, like linux on the RPi4b, etc. and I’m honestly not very inclined to do so because my ability with Linux is horrible – I’ve tried over the years but to me it just seems way over my head. Experimenting with Docker was already a pretty big leap for me
Yes, that’s correct. Without having proper support of host network mode on Mac/Windows, I think that’s probably why I’m running into these weird issues. What you said @koying, makes a lot of sense now … without host network mode, I’ve been seeing a lot of IPs referenced in the 172.XX.XX.XX range.
For reference, everything I’ve been running works perfectly fine with this docker-compose below. Nothing complex, but happy that everything worked … up to this point. Just too bad that things started to get weird …
I spent a good chunk of time reading through your opening post over there and I gotta say, everything went over my head. I mean EVERYTHING. It is clearly much beyond my comprehension
Edit: as I’m scrolling through all the posts further down, i can see what I can try to adapt but I’ll definitely need more time … haha
