I recently installed home assistant - setup works like a charm! Now I want to integrate the little thingies I buildt on my own based on raspi zeros and esp8266 with own software over the years. I came across the API and successfully sent REST requests with the 10 year token, this is easy so far.
Now I am stuck: How do I create virtual entities in home assistant that I can set values through the api? How can I send Jpeg Images to Home assistant from other systems (e.g. my self buildt doorlock/bell/camera with camera based on a raspi zero w)? I think I am missing one essential concept or information and would be grateful if someone could give me a tip. Thanks in advance!
without knowing which devices you need to integrate or exactly how your devices communicate aside from generic REST API then you should start at the integrations page and do a search on “rest”
Thanks, I browsed that but they seem to poll endpoints. I would like to go the other way around and access HA from the device and deliver information through the REST interface of Home Assistant. Or do I oversee something?
Thanks, This I also browsed but did not find what I am searching for. I want to access my HA with a REST request https://xxx.yyy.zzz.sss:8123/api/… I found how to do that with a JSON request but I am missing the part inside Home Assistant how to create the endpoint that I can access that way.
Thanks. I am used to http REST apis so I would like to use that protocol. The problem is not the protocol, its WHAT DO I HAVE TO DO IN HA TO CREATE AN ENTITY that I can access from outside.
I just discovered PUSH and could soucessfully send an Image through HTTP but where is that image going? I am really confused,
I was able to integrate my ip cameras through config.yaml. There must be something lile that for creating an entity I can access via rest from outside…
Create entities using YAML file and attach their statuses and actions to input helpers and scripts
One example, you have a room temperature sensor and you are measuring with pi and you would like to send this value to HA. Create one input helper and using YAML FILE, create a template sensor and set the value of input helper using rest calls.
I have a garage door cover, which is made up with one switch and one proximity sensor. If sensor is closed, garage door shown as closed. If i click on garage door to close or open, it calls switch’s open and close actions.
Thanks and sorry for responding this late - unfortunately I cannot spend the amount of time on this topic I would like to
I think this answer should help, I have a lot of sensors that currently send messages directly to telegram -so its much less effort to make them notify HA instead of enabling them to be polled by HA.
