I used to run my Home Assistant on Raspberry Pi 3 using docker with docker-compose. The used image was: image: homeassistant/home-assistant:stable
. As I recently bought an RPi 4 to replace the 3, I want to move the installation over.
I use basically the same docker-compose file, only the image: homeassistant/raspberrypi4-homeassistant:stable
which seems to be the recommend one for RPi 4. I copyied the config-directory over and adapted the mount point.
However, each time I start the container and try to login, I am greeted with the onboarding assistant, asking me to create a user. Creating a user of the same name, gives an InvalidUser exception in the log. Also, the log gives messages about integrations, I set up on the old installation. So, basically the takeover seems to be successful, but it still asks me to onboard.
I tried to delete home-assistant_v2.db*
as I read somewhere, but that changed nothing. Also, I read about a procedure to first start a vanilla container, stop it and copy the old config-directory over. Tried that, same result.
What is the correct procedure to migrate from one installation to a new one and taking the configuration with me?
Thanks!
