Migrating to new template integration from legacy, can someone verify?
I have 3 old templates that are completely unlike each other. I tried my best to convert/consolidate them to the new template integration. Can someone please confirm the new consolidated templates are effectively identical to the legacy? Once I know these are functionally identical to each other (including their respective names), I can proceed with migrating all my other similar templates.
Legacy templates:
    sensors:
      horizon_c_drive_read_bytes:
        value_template: >-
                {% set read_byte = state_attr('sensor.diskio_0', 'read_bytes') %}
                {% set time_since = state_attr('sensor.diskio_0', 'time_since_update') %}
                {% if (read_byte != None ) and (time_since != None ) %}
                  {{ ((read_byte | int) / (time_since | int) / 1000000) | round (2) }}
                {% endif %}
        availability_template: >-
                {{ states("sensor.diskio_0") not in ["unknown", "unavailable", "none"] }}
        unit_of_measurement: 'MB/s'
    sensors:
      tautulli_total_bandwidth:
        friendly_name: 'Total bandwidth'
        value_template: "{{ (states('sensor.total_bandwidth') | int / 1000) | round(2) }}"
          {{ states("sensor.total_bandwidth") not in ["unknown", "unavailable", "none"] }}
        unit_of_measurement: "Mbps"
binary_sensor:
    sensors:
      plex_plex_for_android_mobile_galaxy_note9_is_visible:
        value_template: >
          {{ states('media_player.plex_plex_for_android_mobile_galaxy_note9') in ['on', 'playing', 'paused'] }}
New template integration: (consolidated)
template:
  - sensors:
      - name: "horizon c drive read bytes"
        state: >
          {% endif %}
        availability: "{{ states('sensor.diskio_0') not in ['unknown', 'unavailable', 'none'] }}"
        unit_of_measurement: "MB/s"
      - name: "tautulli total bandwidth"
        state: "{{ (states('sensor.total_bandwidth') | int / 1000) | round(2) }}"
        availability: "{{ states('sensor.total_bandwidth') not in ['unknown', 'unavailable', 'none'] }}"
        unit_of_measurement: "GB"
  - binary_sensor:
        - name: "plex plex for android mobile galaxy note9 is visible"
          state: "{{ states('media_player.plex_plex_for_android_mobile_galaxy_note9') in ['on', 'playing', 'paused'] }}"
For example, I’m not even sure which binary sensor below uses the correct format (to function identically to my old-format respective binary sensor). If they are both correct, maybe someone could suggest which way would be more common/preferred:
  - binary_sensor:
  - binary_sensor:
        state: >
…also, I’m not sure if I’m using parenthesis correctly in the line below:
The multi-line indicators, > or |, are normally only used if your template is long or you want to break it up visually. They are not necessary. If you do want to use them I would recommend getting in the habit of using |… I’ve seen some issues with > being overwritten to quotation marks when used in the UI editors. This isn’t usually a problem, but occasionally it will cause errors that can be frustrating to figure out.
Your parentheses are fine.
For what it’s worth, you can simplify your availability templates by using has_value('sensor.example').
Thank you for explaining. That helped a lot.
Could you please give me a full example of how to use has_value('sensor.example')? …Assuming it is replacing:
Do I just do this?
availability: "{{ has_value('sensor.total_bandwidth') }}"
Either should work:
availability: "{{ 'sensor.total_bandwidth' | has_value }}"
