Migrating to OS with Addons
I have been running HA Container for a while now and I have decided that I want to switch to OS to use dedicated hardware and get the benefit of the Supervisor. With my current install I am using Node Red, Deconz, and Mosquitto in Docker containers. Is it as simple as copying the data from each of the config folders on my existing install to the corresponding folders in OS with the relevant addons installed? The only thing that I am confident about migrating is the HA config, I want to be sure that all the data for the other components is maintained.
You can’t use the configuration for mosquitto etc. from your Container setup, you need to set up the add-ons from scratch.
Thanks, so even with Node Red I have to recreate all my automations? There’s no way to migrate them across? Will I also have to re-pair all my Zigbee devices with Deconz? If that’s the case then this is a definite no go for me.
Node-Red is super simple.
Just export/import your flows using the menu (top right)
If I use the export from the menu though I will have to reconfigure every flow with the new connection details after importing them. If it is possible to copy the configuration data from one Node Red folder to the other then that won’t be necessary, I was hoping that it would just be a straight file copy.
Ahh - I only have a few unique connections, so no biggie for me…
