I currently run a small Z-Wave network on a Raspberry PI3 with an UZB1 stick. I would like to (try?) to switch to Home Assistant and want to migrate my Network, HA and FHEM are running on the same machine.
Is there a way to just move/migrate the existing network (or have HA read it from the stick) or do I have to remove and add all devices from within HA?
The list of included devices is held in the Z-Wave stick. You can simply stop both, configure Z-Wave in Home Assistant, and start HA up as long as you’re not using secure inclusion. If you are you’ll also need to copy the key over.
Note that renaming Z-Wave devices is now done in the entity registry - updates to the docs is waiting on developer approval.
