@darkxst I got the ZB-GW04 1.2 today and flashed the Openthread RCP using the web flasher. Flashing was successful, but after this homeassistant wasn’t able to find it as a border router.
I tried to use the web flasher and the connection was failing this time with the below logs.
2023-10-12 18:26:17 emscripten universal_silabs_flasher.flasher[42] INFO Probing ApplicationType.EZSP at 115200 baud
2023-10-12 18:26:17 emscripten zigpy.serial[42] DEBUG Opening a serial connection to '/dev/webserial' (115200 baudrate)
2023-10-12 18:26:17 emscripten bellows.ezsp[42] DEBUG Resetting EZSP
2023-10-12 18:26:17 emscripten bellows.uart[42] DEBUG Resetting ASH
2023-10-12 18:26:17 emscripten bellows.uart[42] DEBUG Sending: b'1ac038bc7e'
2023-10-12 18:26:22 emscripten bellows.uart[42] DEBUG Connection lost: None
2023-10-12 18:26:22 emscripten bellows.uart[42] DEBUG Closed serial connection
2023-10-12 18:26:22 emscripten universal_silabs_flasher.flasher[42] INFO Probing ApplicationType.SPINEL at 460800 baud
2023-10-12 18:26:22 emscripten zigpy.serial[42] DEBUG Opening a serial connection to '/dev/webserial' (460800 baudrate)
2023-10-12 18:26:22 emscripten universal_silabs_flasher.common[42] DEBUG Connection made: <webserial_transport.WebSerialTransport object at 0x18e29c8>
2023-10-12 18:26:22 emscripten universal_silabs_flasher.spinel[42] DEBUG Sending frame SpinelFrame(header=SpinelHeader(transaction_id=3, network_link_id=0, flag=2), command_id=<CommandID.PROP_VALUE_GET: 2>, data=b'\x02')
2023-10-12 18:26:22 emscripten universal_silabs_flasher.common[42] DEBUG Sending data b'~\x83\x02\x02\xe65~'
2023-10-12 18:26:23 emscripten universal_silabs_flasher.spinel[42] DEBUG Failed to send SpinelFrame(header=SpinelHeader(network_link_id=0, flag=2), command_id=<CommandID.PROP_VALUE_GET: 2>, data=b'\x02'), trying again in 0.10s (attempt 1 of 4)
2023-10-12 18:26:23 emscripten universal_silabs_flasher.spinel[42] DEBUG Sending frame SpinelFrame(header=SpinelHeader(transaction_id=3, network_link_id=0, flag=2), command_id=<CommandID.PROP_VALUE_GET: 2>, data=b'\x02')
2023-10-12 18:26:23 emscripten universal_silabs_flasher.common[42] DEBUG Sending data b'~\x83\x02\x02\xe65~'
2023-10-12 18:26:24 emscripten universal_silabs_flasher.spinel[42] DEBUG Failed to send SpinelFrame(header=SpinelHeader(network_link_id=0, flag=2), command_id=<CommandID.PROP_VALUE_GET: 2>, data=b'\x02'), trying again in 0.10s (attempt 2 of 4)
2023-10-12 18:26:24 emscripten universal_silabs_flasher.spinel[42] DEBUG Sending frame SpinelFrame(header=SpinelHeader(transaction_id=3, network_link_id=0, flag=2), command_id=<CommandID.PROP_VALUE_GET: 2>, data=b'\x02')
2023-10-12 18:26:24 emscripten universal_silabs_flasher.common[42] DEBUG Sending data b'~\x83\x02\x02\xe65~'
2023-10-12 18:26:26 emscripten universal_silabs_flasher.spinel[42] DEBUG Failed to send SpinelFrame(header=SpinelHeader(network_link_id=0, flag=2), command_id=<CommandID.PROP_VALUE_GET: 2>, data=b'\x02'), trying again in 0.10s (attempt 3 of 4)
2023-10-12 18:26:26 emscripten universal_silabs_flasher.spinel[42] DEBUG Sending frame SpinelFrame(header=SpinelHeader(transaction_id=3, network_link_id=0, flag=2), command_id=<CommandID.PROP_VALUE_GET: 2>, data=b'\x02')
2023-10-12 18:26:26 emscripten universal_silabs_flasher.common[42] DEBUG Sending data b'~\x83\x02\x02\xe65~'
2023-10-12 18:26:27 emscripten universal_silabs_flasher.spinel[42] DEBUG Failed to send SpinelFrame(header=SpinelHeader(network_link_id=0, flag=2), command_id=<CommandID.PROP_VALUE_GET: 2>, data=b'\x02'), trying again in 0.10s (attempt 4 of 4)
I then tried the universal-silabs-flasher python script and that was not able to probe as well. I was finally able to flash a zigbee firmware using SecureCRT. After this, the web flasher detects it again and able to flash the Openthread firmware. This was again bricked. Flashed Zigbee firmware again with SecureCRT and the tried the Multi PAN firmware. This seems to work fine. After flashing multi pan, The web flasher can still connect to the device.
Now I have multi pan firmware running, but will only using this stick for Thread.
Wondering if there could be a bug with the Openthread flashing with the web flasher…
