I have an existing HA OS install on a VM running on hardware today without issue. Combination of Zigbee, Zwave, Matter, and other devices. I am moving to new hardware and a new VM setup with HA OS. I have the new hardware up and running, including the new VM. After the initial setup/install on the new hardware/VM I restored from a full backup of my existing install.
I am using the HomeAssistant Z-Wave JS Integration
Overall everything restored beautifully and the new VM setup is up and running. I also moved over my dongles for both Zigbee and Zwave (HomeAssistant Sky Connect and ZOOZ ZST10 700 respectively) and HomeAssistant saw them right away and sucesfully started the integrations. Zigbee and Matter work fine, but while Zwave started the integration fine without error, the devices are not connected/responding. I spun back up the old VM/install and put the sticks back, and everything works fine there. My understanding is that there are keys in the ZOOZ stick and in the installation. It seems like everything came over in the restore, but maybe there is something else I have to do manually? I already tried a partial backup of JUST Zwave and manually restoring some of the files (jsonl, metadata, values), but there was another “data” section that had “Devices” files that I couldnt’ locate in my instance to replace.
Any ideas what is going on here or what I need to do? I am back on my old install right now while I try to figure this out. I’m hoping to avoid removing and re-adding all of my nearly 20 Zwave devices.
