I’ve installed Homematic(IP) Local, finally! I’ve set all parameters and it works fine.
Currently I’m using the old proprietary Homematic integration and Homematic(IP) local at the same time. But that’s only an interim solution.
I’d like to migrate all old entities to the new one and keep my automations, scripts and history untouched.
My first attempt: delete the old one and rename the new one with the same entity-id as the old one.
But it isn’t possible to delete a single entity from the old homematic integration.
Do you have any other idea, how to migrate smoothly with smallest possible impact?
Thanks for any tip!
