I noticed that with my Victron Venus MQTT integration (~50+ messages/sec) as well as more complex dashboards and… and… and… the old Pi3B with passive cooling was struggling a little.
So I sprung for an upgrade to a Pi4 in an ArgonOne case… My observations are this:
- The migration functionality by restoring snapshots was a breeze. Just needed to fidget with my static IP configurations a little to get the new device to replace my old and demote the old Pi3B to a “dev environment”
- The ArgonOne case is wonderful. In winter the house is at about 16 degrees and once the fan control is set up, even under a hammering the temperature is < 40 with the fan off. Turning the fan on at max only drops the temperature by 4 degrees, but lets see how that works out in Summer. Setting the fan control up was tedious given that the Pi4 is a bit different than the standard I2C guide see here
- The shocker though - I didn’t notice any WIFI degradation at all since I run the system wired. However, Bluetooth and BLE connectivity was radically reduced by the signal degradation as a result of the enclosed metal case (I assume this is not due to a weaker radio in the Pi4). So sadly I will have to replace my solitary MiFlora sensor with an ESP based one or get a Bluetooth dongle of some sort. What used to be a fairly workable integration at 5-6m range is now non-responsive unless the device is <1M away from the Pi4.
Overall I can recommend the ArgonOne + Pi4 but just watch out for that bluetooth and wifi signal attenuation.
