Hi. I know there are multiple of threads related to this on the internet, but I couldn’t find a solution. I have Aqara radiators and temperature sensors paired with my HAY using ZHA. Unfortunately, Zigbee Home Automation integration doesn’t provide the possibility to use external sensors for the radiators, so I decided to move to zigbee2mqtt.
I’m having trouble enabling the service. Here’s the log
[17:57:37] INFO: Preparing to start...
[17:57:37] INFO: Socat not enabled
[17:57:40] INFO: Starting Zigbee2MQTT...
Zigbee2MQTT:info 2023-11-22 17:57:47: Logging to console and directory: '/config/zigbee2mqtt/log/2023-11-22.17-57-46' filename: log.txt
Zigbee2MQTT:info 2023-11-22 17:57:47: Starting Zigbee2MQTT version 1.33.2 (commit #unknown)
Zigbee2MQTT:info 2023-11-22 17:57:47: Starting zigbee-herdsman (0.21.0) Zigbee2MQTT:error 2023-11-22 17:58:07: Error while starting zigbee-herdsman Zigbee2MQTT:error 2023-11-22 17:58:07: Failed to start zigbee Zigbee2MQTT:error 2023-11-22 17:58:07: Check https://www.zigbee2mqtt.io/guide/installation/20\_zigbee2mqtt-fails-to-start.html for possible solutions Zigbee2MQTT:error 2023-11-22 17:58:07: Exiting...
Zigbee2MQTT:error 2023-11-22 17:58:08: Error: Connection not initialized at Ezsp.execCommand (/app/node\_modules/zigbee-herdsman/src/adapter/ezsp/driver/ezsp.ts:551:19) at Ezsp.version (/app/node\_modules/zigbee-herdsman/src/adapter/ezsp/driver/ezsp.ts:349:35) at Driver.startup (/app/node\_modules/zigbee-herdsman/src/adapter/ezsp/driver/driver.ts:140:25) at EZSPAdapter.start (/app/node\_modules/zigbee-herdsman/src/adapter/ezsp/adapter/ezspAdapter.ts:172:16) at Controller.start (/app/node\_modules/zigbee-herdsman/src/controller/controller.ts:132:29) at Zigbee.start (/app/lib/zigbee.ts:60:27) at Controller.start (/app/lib/controller.ts:101:27) at start (/app/index.js:107:5)
And here’s the config
data_path: /config/zigbee2mqtt
socat:
enabled: false
master: pty,raw,echo=0,link=/tmp/ttyZ2M,mode=777
slave: tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5
options: "-d -d"
log: false
mqtt:
base_topic: zigbee2mqtt
serial:
port: /dev/ttyAMA1
baudrate: 115200
rtscts: false
adapter: ezsp
I tried disabling the ZHA and then starting the Z2A, but it didn’t work.
