Migration guide SD to SSD
Is there a recommended migration guide for noobs like me to assist in migrating my running Pi4/Hass setup from SD card to SSD drive???
I have samba doing a daily backup to a NAS so i do have a copy of my install hopefully but have heard that SD cards don’t live long in this use?
This was the guide I followed. I didn’t document my exact steps, but basically imaged a new Raspberry Pi OS on a spare SD card, booted from that card and updated the EEPROM so the Pi will now boot from USB if no SD is present. Next I imaged the SSD with the latest 64 bit 5.x image on a laptop, then booted from the SSD. After I was able to log into the new HA install I restored my latest snapshot. Everything worked perfectly with the exception of 2 zigbee door sensors that showed as ‘unavailable’ , but those just needed to be activated one time and they started working. I did need to buy a new SATA to USB3 adapter, as my old one would not allow it to boot. I’m using an SSD drive I had removed from a laptop in 2014 and it’s been working great! I was surprised at how easy it really was.
Great, thanks for that, i was going to get one of these, lucky i waited :wink:
https://www.amazon.co.uk/dp/B07MHVZJPX/?coliid=I1SU00582FAS36&colid=3OB6BK1IOHHQH&psc=1
I have an RPi4 with a HASS OS on it and i made this:
  1. Created a full backup of the current system. Settings → System → Backups
  2. Downloaded that backup to my PC
  3. Burned a new HASS OS image to my SSD
  4. Burned a new bootloader for RPi4 to SD card using this guide. I used USB boot bootloader.
  5. Flashed the new bootloader to the RPi.
  6. Installed the SSD and removed the SD
  7. When HASS OS has loaded, I simply restored the backup, which I created earlier.
