Migration of Python-Matter-Server Docker container to Matter.js with HA 2026.2?
I read about HA 2026.2 to replace Python-Matter-Server with Matter.js. I currently run HA in a Docker container, and Python-Matter-Server in another container.
What’s the way to migrate? Will there be a new Docker image that contains Matter.js and is able to automatically migrate data from Python-Matter-Server? Or will Matter.js be included with the HA Docker image in future?
Both python and node.js versions come with the AddON. You can enable the Beta version of the Matter Server AddOn (and then restart the AddOn) to try out Matter.js, and it should auto-migrate. You can also subsequently disable the Beta version (and restart the AddOn) to get back to the python based version.
Same question here. HA is migrating from the legacy Python-based Matter Server to a new JS-based version (Matter (.js) Server). They say that the new version is a “drop-in” replacement. The migration is seamless for users of the Matter Server add-on; however, is it so for installations that run the Matter Server (Python) on a remote container? And if so, what’s the migration route? I guess we simply create the new image pointing it at the same storage used by the old one.
Does anyone know or has tried?
The current migration route for docker installs is linked above, I am sure this will be similar or easier once the beta is over. With first start of the beta importing the python server data takes a while, but after that the Matter-JS server is much faster in every way already.
Excellent. Thanks!
I migrated about a week ago. I use docker swarm with disk connections on a NAS. The only way I could get this to “upgrade” was to move the files locally to the one of the swarm node and then it flew through the first time upgrade. I notice it creates a lot of files. The server seems very disk speed sensitive. My AS was doing a snapshot prune and lights would take forever to respond and have HA update. Is the new server supposed to be so disk speed dependent? I hadn’t had problems with the older python server, but it does not use all the files. have about 140 matter devices. has anyone else seen this behavior?
I migrated last week too. Painless, and have seen no issues. But my storage is all local and I only have about 5 Matter devices.
You could ask the Main Dev over on the Discord channel dedicated to the new Matterjs-server. He is very responsive.
