hi,
i migrated my setup to VM and some zigbee for example as log below stopped to work … any idea?
Zigbee2MQTT:error 2022-08-09 17:54:59: Publish 'set' 'state' to 'K-power-socket' failed: 'Error: Command 0xa4c13815190b8e94/1 genOnOff.off({}, {"sendWhen":"immediate","timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Data request failed with error: 'MAC channel access failure' (225))'
Zigbee2MQTT:debug 2022-08-09 17:54:59: Error: Command 0xa4c13815190b8e94/1 genOnOff.off({}, {"sendWhen":"immediate","timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Data request failed with error: 'MAC channel access failure' (225))
at ZStackAdapter.sendZclFrameToEndpointInternal (/app/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:414:23)
at Queue.executeNext (/app/node_modules/zigbee-herdsman/src/utils/queue.ts:32:32)
Zigbee2MQTT:info 2022-08-09 17:54:59: MQTT publish: topic 'zigbee2mqtt/bridge/log', payload '{"message":"Publish 'set' 'state' to 'K-power-socket' failed: 'Error: Command 0xa4c13815190b8e94/1 genOnOff.off({}, {\"sendWhen\":\"immediate\",\"timeout\":10000,\"disableResponse\":false,\"disableRecovery\":false,\"disableDefaultResponse\":false,\"direction\":0,\"srcEndpoint\":null,\"reservedBits\":0,\"manufacturerCode\":null,\"transactionSequenceNumber\":null,\"writeUndiv\":false}) failed (Data request failed with error: 'MAC channel access failure' (225))'","meta":{"friendly_name":"K-power-socket"},"type":"zigbee_publish_error"}'
debug 2022-08-09 18:01:58Error: Command 0xa4c13815190b8e94/1 genOnOff.on({}, {"sendWhen":"immediate","timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Data request failed with error: 'MAC channel access failure' (225)) at ZStackAdapter.sendZclFrameToEndpointInternal (/app/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:414:23) at Queue.executeNext (/app/node_modules/zigbee-herdsman/src/utils/queue.ts:32:32)
and i think issue happened since i upgraded hass / os / + zigbee plugin
Zigbee2MQTT
Current version: 1.27.0-1
(Changelog)
thanks!
