I currently have 2021.6.6 installed and works fine with DuckDNS and LetsEncrypt. If I upgrade to .7 and nothing else is changed, LetsEncrypt AddOn does not start. Looked at the release notes to see if there are any breaking changes, did not see/notice. If anyone has encountered it and has a suggestion to remedy greatly appreciated.
LetsEncrypt still working here. There were no changes to it.
Do you use a reverse proxy like NGINX?
Yes I do have that running, without that Google TTS does not work.
Got it. Thankyou, missed the proxy use.
I followed the above instructions and added the two lines under http. It is still not working. Any suggestions?
use_x_forwarded_for: True
trusted_proxies:'
- 127.0.0.1'
- ::1'
- 192.168.1.0/24'
What is the error message in your logs?
What are those doing at the end of the lines?
Also use true not True
that was an typo on my part when I was typing in the post here.
Lets Encrypt service log:
[s6-init] making user provided files available at /var/run/s6/etc…exited 0.
[s6-init] ensuring user provided files have correct perms…exited 0.
[fix-attrs.d] applying ownership & permissions fixes…
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts…
[cont-init.d] file-structure.sh: executing…
[cont-init.d] file-structure.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[23:07:26] INFO: Selected http verification
Saving debug log to /var/log/letsencrypt/letsencrypt.log
Plugins selected: Authenticator standalone, Installer None
Cert not yet due for renewal
Keeping the existing certificate
Certificate not yet due for renewal; no action taken.
[cont-finish.d] executing container finish scripts…
[cont-finish.d] done.
[s6-finish] waiting for services.
[s6-finish] sending all processes the TERM signal.
My nginx ssl proxy config:
domain: RPI4.duckdns.org
certfile: fullchain.pem
keyfile: privkey.pem
hsts: max-age=31536000; includeSubDomains
cloudflare: false
customize:
active: false
default: nginx_proxy_default*.conf
servers: nginx_proxy/*.conf
Your home assistant logs. It should show what proxy IP address to add.
Got it working. Thank you. It was one line I missed adding to my http config. Once I added this line and rebooted, it works fine now
- 172.30.33.0/24
I had a similar problem after upgrading, as I’m using Cloudflare to redirect my hostname to an IPV6 address nothing was getting through.
I added use_x_forwarded_for and for trusted_proxies also had to add one of the IPV6 ranges from their list here https://www.cloudflare.com/en-gb/ips/ although its possible I might need to add more if I have more issues
