Hi everyone,
I’m currently considering migrating from Home Assistant (the old Hassio) to HOme Assistant Supervised on my Intel Nuc, and am looking for opinions / advice on (1) whether this is a good idea and (2) the best process to do so.
It’s kind of a long story, so I’ll hide some of it in “Detailed” sections for those wanting more info.
(Click on the arrow to expand a section)
My current setup is Home Assistant on ESXi together with some other VM's
So, on my i7 nuc I have ESXi running. On this I have four VM’s:
- Home Assistant
- Debian with ZoneMinder
- Win10 with several installer/manager tools for my home
- A 3CX pbx which I am phasing out.
Initially I had more, for experimenting and such, but as my setup has become more stable I find I don’t need these anymore.
My home automation setup is quite extensive, and I feel I'm not getting the most out of my nuc.
I have a lot of devices connected to / controlled by my NUC, over LAN and USB. To give you an idea: KNX, 2xOpenThermGW, Comfocontrol, Unifi network, RFXTRX, deconz, Modbus Gateways, …
Now with my current setup I litterally split my nuc up into parts. For one this can’t be ideal for perfomance and secondly, I have to manage the different VM’s separately.
So the idea is to put everything on Debian with a single VM for running Win10 when needed
So I was thinking to migrate my Home Assistant to a Supervised installation on Debian running on the “bare metal” of the Nuc. On this install I would also run Zoneminder. As said, I will be removing the PBX and I could run the Win10 computer when I need it in VMWare player.
And here comes the first question: with this information & your experience, do you think this is a good idea?
Now, the plan for the migration is as follows:
- Make a snapshot of my current Home Assistant setup.
- Install this on a “fresh” RPI4 to keep my house running while I shut down the vm.
- Migrate the Win10 computer to VMWare Player
- Completely cleanup the Nuc and install Debian.
- Install Home Assistant Supervised and ZoneMinder (have to think about what ports to run the services on I think)
- Install VMWare Player and move over the VM of my Win 10 PC.
- Sit back and enjoy
And now the second question: does this make sense?
Some caveats/questions I already am aware of:
- I will have to re-setup my ZoneMinder and will lose all video I have recorded; I have no problem with that.
- I have to limit the amount of experimenting I do on the system as this is an all-in-one solution.
- Not sure with how this will work running multiple webservices on the single PC on (I suppose) 1 IP. Maybe I can give them different ports.
- Probably VMWare Player is not the best virtualization solution for my Win10, but I am looking for something which will easily let me convert my ESXi image to a VM which can be run on top of Debian.
Any thoughts you guys might have on this topic are welcome!
Thanks,
Thomas
