(TLDR at bottom)
So today I planned to migrate everything to Z-wave JS. Sadly it failed (but thanks to a backup I was back up and running the old way in 2 minutes so that was great!).
The one’s it migrated also only got the name Node1 - Node 43, not really usefull to know what they do (the names showed correctly in the list “this will be migrated” though).
Currently I am still using the first Z-wave implementation with the Aeotec Gen5 stick and it works fine and stable for years now. But I recently bought 2 extra sensors (Aeotec Multisensor 7 and and Aeotec Tri-sensor).
For some reason these don’t seem to work with the old integration. At least I can’t get them to work. They link just fine, but the tri-sensor doesn’t report anything correctly and the Multi-sensor is linked but device type unknown. The other values it reports are also incorrect.
I was holding off to migrate to Z-wave JS because I have 85 devices and 456 entities on Z-wave. Compatibility should be fine I think as the devices are all visible in the device database of Z wave JS (Fibaro Dimmer 2, RGBW and blind controllers, Aeotec power meters, a tri- and multisensor, nothing exotic)
Now I figured, the Multisensor 7 probably doesn’t fully work with the Gen5+ stick anyway.
Can I buy a Aeotec Gen7 stick (compatible according to the documentation), link that to Z-wave JS and use my new sensors on Z-wave JS. Meanwhile keeping the Gen5 stick in the old integration and keep using that.
That would give me a lot more room to migrate everything piece by piece over time instead of needing to get it done in one day.
Anyone that performed this type of migration? I’ve already red some posts of people trying to get a backup of the Gen5 stick on the Gen7 stick but that’s not possible so I’m not even going try that (same with the backup-stick changing to main stick method).
TLDR:
Migration to Z-wave JS failed. Restore went fine so no issue. Can I use a Gen7 stick in Z-wave JS while keeping to use my Gen5 stick in the old integration, to migrate everything slowly over time?
