dankoj
(Danko Jevtovic)
October 27, 2021, 10:26am
1
My Mikrotik RouterOS integration fails to setup. I am using non-ascii (unicode characters) in my comments and DHCP device names.
I see a fix in GitHub, but it doesn’t work for my (current HA build, routerOS 6.49)
home-assistant:dev
← Janhouse:mikrotik-encoding-fix
opened 12:54AM - 23 Jul 20 UTC
You are amazing! Thanks for contributing to our project!
Please, DO N… OT DELETE ANY TEXT from this template! (unless instructed).
## Proposed change
Describe the big picture of your changes here to communicate to the
maintainers why we should accept this pull request. If it fixes a bug
or resolves a feature request, be sure to link to that issue in the
additional information section.
I just specify utf8 encoding for Mikrotik api protocol in Mikrotik component.
Short story: I have Wifi name that uses emoji in it and without specifying encoding, component doesn't work.
Here is the problem:
``` File "/usr/src/homeassistant/homeassistant/components/mikrotik/hub.py", line 141, in get_hub_details
self.support_wireless = bool(self.command(MIKROTIK_SERVICES[IS_WIRELESS]))
File "/usr/src/homeassistant/homeassistant/components/mikrotik/hub.py", line 249, in command
response = list(self.api(cmd=cmd))
File "/usr/local/lib/python3.8/site-packages/librouteros/api.py", line 28, in __call__
yield from self.readResponse()
File "/usr/local/lib/python3.8/site-packages/librouteros/api.py", line 60, in readResponse
reply_word, words = self.readSentence()
File "/usr/local/lib/python3.8/site-packages/librouteros/api.py", line 46, in readSentence
reply_word, words = self.protocol.readSentence()
File "/usr/local/lib/python3.8/site-packages/librouteros/protocol.py", line 189, in readSentence
sentence = tuple(word for word in iter(self.readWord, ''))
File "/usr/local/lib/python3.8/site-packages/librouteros/protocol.py", line 189, in <genexpr>
File "/usr/local/lib/python3.8/site-packages/librouteros/protocol.py", line 206, in readWord
return word.decode(encoding=self.encoding, errors='strict')
UnicodeDecodeError: 'ascii' codec can't decode byte 0xf0 in position 6: ordinal not in range(128)
I have specified utf8 to be used for communication with Mikrotik API. Not sure if you need any additional tests and other things for this simple PR.
This is a super tiny change, I'm using it locally and it works.
## Type of change
What type of change does your PR introduce to Home Assistant?
NOTE: Please, check only 1! box!
If your PR requires multiple boxes to be checked, you'll most likely need to
split it into multiple PRs. This makes things easier and faster to code review.
- [ ] Dependency upgrade
- [X] Bugfix (non-breaking change which fixes an issue)
- [ ] New integration (thank you!)
- [ ] New feature (which adds functionality to an existing integration)
- [ ] Breaking change (fix/feature causing existing functionality to break)
- [ ] Code quality improvements to existing code or addition of tests
## Additional information
Details are important, and help maintainers processing your PR.
Please be sure to fill out additional details, if applicable.
- This PR fixes or closes issue: fixes #
- This PR is related to issue:
- Link to documentation pull request:
## Checklist
Put an `x` in the boxes that apply. You can also fill these out after
creating the PR. If you're unsure about any of them, don't hesitate to ask.
We're here to help! This is simply a reminder of what we are going to look
for before merging your code.
- [X] The code change is tested and works locally.
- [X] Local tests pass. **Your PR cannot be merged unless tests pass**
- [X] There is no commented out code in this PR.
- [ ] I have followed the [development checklist][dev-checklist]
- [ ] The code has been formatted using Black (`black --fast homeassistant tests`)
- [ ] Tests have been added to verify that the new code works.
If user exposed functionality or configuration variables are added/changed:
- [ ] Documentation added/updated for [www.home-assistant.io][docs-repository]
If the code communicates with devices, web services, or third-party tools:
- [ ] The [manifest file][manifest-docs] has all fields filled out correctly.
Updated and included derived files by running: `python3 -m script.hassfest`.
- [ ] New or updated dependencies have been added to `requirements_all.txt`.
Updated by running `python3 -m script.gen_requirements_all`.
- [ ] Untested files have been added to `.coveragerc`.
The integration reached or maintains the following [Integration Quality Scale][quality-scale]:
The Integration Quality Scale scores an integration on the code quality
and user experience. Each level of the quality scale consists of a list
of requirements. We highly recommend getting your integration scored!
- [ ] No score or internal
- [ ] 🥈 Silver
- [ ] 🥇 Gold
- [ ] 🏆 Platinum
Thank you for contributing <3
Below, some useful links you could explore:
[dev-checklist]: https://developers.home-assistant.io/docs/en/development_checklist.html
[manifest-docs]: https://developers.home-assistant.io/docs/en/creating_integration_manifest.html
[quality-scale]: https://developers.home-assistant.io/docs/en/next/integration_quality_scale_index.html
[docs-repository]: https://github.com/home-assistant/home-assistant.io
The error log:
Logger: homeassistant.config_entries
Source: components/mikrotik/hub.py:259
First occurred: 08:58:46 (1 occurrences)
Last logged: 08:58:46
Error setting up entry Mikrotik for mikrotik
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 304, in async_setup
result = await component.async_setup_entry(hass, self) # type: ignore
File "/usr/src/homeassistant/homeassistant/components/mikrotik/__init__.py", line 73, in async_setup_entry
if not await hub.async_setup():
File "/usr/src/homeassistant/homeassistant/components/mikrotik/hub.py", line 387, in async_setup
await self.hass.async_add_executor_job(self._mk_data.update)
File "/usr/local/lib/python3.9/concurrent/futures/thread.py", line 52, in run
File "/usr/src/homeassistant/homeassistant/components/mikrotik/hub.py", line 283, in update
self.update_devices()
File "/usr/src/homeassistant/homeassistant/components/mikrotik/hub.py", line 178, in update_devices
self.all_devices = self.get_list_from_interface(DHCP)
File "/usr/src/homeassistant/homeassistant/components/mikrotik/hub.py", line 165, in get_list_from_interface
result = self.command(MIKROTIK_SERVICES[interface])
File "/usr/src/homeassistant/homeassistant/components/mikrotik/hub.py", line 259, in command
File "/usr/local/lib/python3.9/site-packages/librouteros/api.py", line 28, in __call__
File "/usr/local/lib/python3.9/site-packages/librouteros/api.py", line 60, in readResponse
File "/usr/local/lib/python3.9/site-packages/librouteros/api.py", line 46, in readSentence
File "/usr/local/lib/python3.9/site-packages/librouteros/protocol.py", line 189, in readSentence
File "/usr/local/lib/python3.9/site-packages/librouteros/protocol.py", line 189, in <genexpr>
File "/usr/local/lib/python3.9/site-packages/librouteros/protocol.py", line 206, in readWord
UnicodeDecodeError: 'utf-8' codec can't decode byte 0xf0 in position 18: invalid continuation byte
SSinSD
(Eric)
November 15, 2021, 7:56pm
2
You can try this, it didn’t work for me, but it did work for the poster:
opened 07:25PM - 10 Dec 20 UTC
closed 12:08AM - 09 Aug 21 UTC
integration: mikrotik
stale
<!-- READ THIS FIRST:
- If you need additional help with this template, pleas… e refer to https://www.home-assistant.io/help/reporting_issues/
- Make sure you are running the latest version of Home Assistant before reporting an issue: https://github.com/home-assistant/core/releases
- Do not report issues for integrations if you are using custom components or integrations.
- Provide as many details as possible. Paste logs, configuration samples and code into the backticks.
DO NOT DELETE ANY TEXT from this template! Otherwise, your issue may be closed without comment.
## The problem
The Mikrotik integration is choking on a Unicode response from the router. If the integration is added with the UI, this prevents it from completing setup. If added directly to configuration.yaml, it appears to prevent updates after the initial response.
This is because, for some reason, my GE Range insists on defining its hostname as "û"
## Environment
Provide details about the versions you are using, which helps us to reproduce
and find the issue quicker. Version information is found in the
Home Assistant frontend: Configuration -> Info.
- Home Assistant Core release with the issue: 0.118.5
- Last working Home Assistant Core release (if known): 0.118.0
- Operating environment (OS/Container/Supervised/Core): Hassio 2020.12.6
- Integration causing this issue: Mikrotik
- Link to integration documentation on our website: https://www.home-assistant.io/integrations/mikrotik
## Problem-relevant `configuration.yaml`
An example configuration that caused the problem for you. Fill this out even
if it seems unimportant to you. Please be sure to remove personal information
like passwords, private URLs and other credentials.
mikrotik:
- name: <HOSTNAME>
host: <IP>
username: homeassistant
password: <PASSWORD>
verify_ssl: false
arp_ping: false
force_dhcp: true
detection_time: 300
## Traceback/Error logs
If you come across any trace or error logs, please provide them.
This is the traceback placed in home_assistant.log when trying to set up the MikroTik integration from the interface.
2020-12-10 14:22:22 ERROR (MainThread) [homeassistant.config_entries] Error setting up entry Mikrotik for mikrotik
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 236, in async_setup
File "/usr/src/homeassistant/homeassistant/components/mikrotik/__init__.py", line 68, in async_setup_entry
File "/usr/src/homeassistant/homeassistant/components/mikrotik/hub.py", line 382, in async_setup
File "/usr/local/lib/python3.8/concurrent/futures/thread.py", line 57, in run
File "/usr/src/homeassistant/homeassistant/components/mikrotik/hub.py", line 278, in update
File "/usr/src/homeassistant/homeassistant/components/mikrotik/hub.py", line 172, in update_devices
File "/usr/src/homeassistant/homeassistant/components/mikrotik/hub.py", line 159, in get_list_from_interface
File "/usr/src/homeassistant/homeassistant/components/mikrotik/hub.py", line 253, in command
UnicodeDecodeError: 'utf-8' codec can't decode byte 0xfb in position 12: invalid start byte
