Special compartment for zigbee radio / storage etc
MicroSD storage expansion
All that for 179$
It's not yet on sale but I intend to buy it specifically for home assistant / home router use
Does anyone here have experience in running home assistant in mikrotik containers? Because this hardware is perfect for it
It's my first post so if my category choice is wrong please let me know
I couldn't find any info on the subject and the router is still very new
That got your hopes absolutely stratospheric, didn't it?
Operating System: RouterOS v7
Size of RAM: 2 GB
I see it may have issues as somewhat underpowered right out of the box if you also want to run a HomeAssistant server simultaneously inside the same box. That 2Gb is overall, not available I suspect and you will bump against memory limitations as you add apps and integrations.
Keep looking. This is a sign of where router technology has to go to keep up with the times. As a router, paired with a separate HomeAssistant box, it could tick a lot of boxes for you.
