Hi, recently activated the Mikrotik integration and added my core router. I mainly wanted to use the integration to capture the routers temperature.
Everything appears to be working, except it doesn’t show any data?
Here’s the log…
2023-03-11 13:24:43.098 DEBUG (SyncWorker_4) [homeassistant.components.mikrotik.hub] Running command /ip/dhcp-server/lease/getall
2023-03-11 13:24:43.098 DEBUG (SyncWorker_4) [librouteros] <--- '/ip/dhcp-server/lease/getall'
2023-03-11 13:24:43.098 DEBUG (SyncWorker_4) [librouteros] <--- EOS
2023-03-11 13:24:43.100 DEBUG (SyncWorker_4) [librouteros] ---> '!done'
2023-03-11 13:24:43.100 DEBUG (SyncWorker_4) [librouteros] ---> EOS
2023-03-11 13:24:43.100 DEBUG (SyncWorker_4) [homeassistant.components.mikrotik.hub] Falling back to DHCP for scanning devices
2023-03-11 13:24:43.100 DEBUG (SyncWorker_4) [homeassistant.components.mikrotik.hub] Running command /system/routerboard/getall
2023-03-11 13:24:43.100 DEBUG (SyncWorker_4) [librouteros] <--- '/system/routerboard/getall'
2023-03-11 13:24:43.100 DEBUG (SyncWorker_4) [librouteros] <--- EOS
2023-03-11 13:24:43.103 DEBUG (SyncWorker_4) [librouteros] ---> '!re'
2023-03-11 13:24:43.103 DEBUG (SyncWorker_4) [librouteros] ---> '=routerboard=true'
2023-03-11 13:24:43.103 DEBUG (SyncWorker_4) [librouteros] ---> '=model=CRS328-24P-4S+'
2023-03-11 13:24:43.103 DEBUG (SyncWorker_4) [librouteros] ---> '=revision=r2'
2023-03-11 13:24:43.103 DEBUG (SyncWorker_4) [librouteros] ---> '=serial-number=<REDACTED>'
2023-03-11 13:24:43.103 DEBUG (SyncWorker_4) [librouteros] ---> '=firmware-type=dx3230L'
2023-03-11 13:24:43.103 DEBUG (SyncWorker_4) [librouteros] ---> '=factory-firmware=6.47.10'
2023-03-11 13:24:43.103 DEBUG (SyncWorker_4) [librouteros] ---> '=current-firmware=7.8'
2023-03-11 13:24:43.103 DEBUG (SyncWorker_4) [librouteros] ---> '=upgrade-firmware=7.8'
2023-03-11 13:24:43.104 DEBUG (SyncWorker_4) [librouteros] ---> EOS
2023-03-11 13:24:43.104 DEBUG (SyncWorker_4) [librouteros] ---> '!done'
2023-03-11 13:24:43.104 DEBUG (MainThread) [homeassistant.components.mikrotik.hub] Finished fetching mikrotik - <REDACTED> data in 0.006 seconds (success: True)
Here’s what I see in the integration…
I assume I am missing something, but not sure what it is? Any tips appreciated.
