Milight YT1 Controller - Anyone tried it?
I was wondering if anyone have tried the YT1 Controller for MiLight in combination with Home Assistant?
It should be doable with the limitless component, but if someone out there already tried it, what would you say the pros and cons are with this device.
Any inputs are appreciated :slight_smile:
Thanks…
Wondering the same, anyone had succes with this device? I tried adding it like the other iBox controller but no succes…
If you are open to alternatives, you can try a DIY project that is superior in all respects to the original MiLight gateway (it has unlimited number of configurable lights - no 4 groups limit, gets status back to HA if other control devices were used, doesn’t require soldering):
Also, HA Limitless component seems to get broken after each HA update (DIY uses MQTT integration)
