Mill heat Norway
I did the Mill app migration and i found some posts from mai juni that worked on the plugin Mill Heat migration to new IoT.
I tryed that “fix” but i cannot se any info in the devices.
it sayes unavalible.
The log sayes that it fetch info from Mill server.
Is there any thing special i need to know about?
Mill integration does not work after migration to new IoT · Issue #95424 · home-assistant/core (github.com)
I deleted the whole integration and added it again, worked here.
I tryed to remove the custom catalog and remove the addon in HASS.
and readd… same issue…
how to “compleate” delete? :slight_smile:
cash? folder?
I deleted the integration from the integrations menu, and added it again, that was it.
strange, it does not work here.
I am able to fetch TVOC sensores in Homey with Mill app.
and get status (but not “ovner”/heaters gen2)
In HASS i can see all devices but all devices are unavailible. (except 1 stand alone heater i cannot se)
I have only Gen2 devices.
I can see in the log that HASS fetch my account and all info.
Maybe this is a bug?
I would try deleting them (start with one) from your Mill app and adding them again. I also only have gen 2.
It did not work :frowning: tryed 2 gen2.
Both unit works in Mill app, but not in HASS (or other smart home)
if any one known about the plugin… and can check…
this is the log…
2023-11-23 07:17:06.109 DEBUG (MainThread) [mill] Result {“timeIdentification”:0,“deviceInfo”:[{“showBusinessLock”:0,“isHoliday”:0,“description”:“”,“holidayTemp”:7,“deviceId”:127621,“deviceName”:“Bad”,“roomId”:202302241052049984,“deviceStatus”:1,“powerStatus”:0,“heaterFlag”:0,“times”:“”,“fanStatus”:0,“holidayTemp_dou”:7.0,“humidity”:0.0,“lock”:0,“deviceType”:1,“tvoc”:0,“fanStatusShow”:0,“showPreHeat”:0,“isManualControl”:0,“electricity”:0.0,“canChangeTemp”:1,“showOpen”:0,“preHeatStatus”:0,“eco2”:0,“subDomainId”:5316,“coolingStatus”:0,“currentTemp”:“–.-”,“showChildLock”:0,“open”:0},{“showBusinessLock”:0,“isHoliday”:0,“description”:“”,“holidayTemp”:7,“deviceId”:127629,“deviceName”:“stua”,“roomId”:202302241052049984,“deviceStatus”:1,“powerStatus”:0,“heaterFlag”:0,“times”:“”,“fanStatus”:0,“holidayTemp_dou”:7.0,“humidity”:0.0,“lock”:0,“deviceType”:1,“tvoc”:0,“fanStatusShow”:0,“showPreHeat”:0,“isManualControl”:0,“electricity”:0.0,“canChangeTemp”:1,“showOpen”:0,“preHeatStatus”:0,“eco2”:0,“subDomainId”:5316,“coolingStatus”:0,“currentTemp”:“–.-”,“showChildLock”:0,“open”:0}]}
2023-11-23 07:17:06.109 DEBUG (MainThread) [mill] SubDomain 5316
2023-11-23 07:17:06.112 DEBUG (MainThread) [mill] Result {“maxTemperature”:0,“isIndependent”:false,“regulatorType”:1,“subDomain”:“5333”,“description”:“”,“holidayTemp”:22,“deviceId”:68167,“deviceName”:“2 etg\n”,“mac”:“98D863307385”,“limited_heating”:100,“deviceStatus”:1,“times”:“”,“powerStatus”:0,“fanStatus”:1,“holidayTemp_dou”:22.0,“humidity”:0.0,“lock”:0,“power”:0,“tvoc”:0,“fanStatusShow”:1,“changeTemperature”:0,“windowsStatus”:0,“electricity”:0.0,“timeIdentification”:0,“preHeatStatus”:0,“eco2”:0,“heatStatus”:0,“controlType”:0,“coolingStatus”:0,“success”:true,“isOffline”:0,“currentTemp”:“–.-”}
2023-11-23 07:17:06.119 DEBUG (MainThread) [mill] Result {“maxTemperature”:0,“isIndependent”:false,“regulatorType”:1,“subDomain”:“5333”,“description”:“”,“holidayTemp”:22,“deviceId”:68169,“deviceName”:“mads soverom”,“mac”:“98D863307447”,“limited_heating”:100,“deviceStatus”:1,“times”:“”,“powerStatus”:0,“fanStatus”:1,“holidayTemp_dou”:22.0,“humidity”:0.0,“lock”:0,“power”:0,“tvoc”:0,“fanStatusShow”:1,“changeTemperature”:0,“windowsStatus”:0,“electricity”:0.0,“timeIdentification”:0,“preHeatStatus”:0,“eco2”:0,“heatStatus”:0,“controlType”:2,“coolingStatus”:0,“success”:true,“isOffline”:0,“currentTemp”:“–.-”}
2023-11-23 07:17:06.162 DEBUG (MainThread) [mill] Result {“timeIdentification”:0,“deviceInfo”:[{“maxTvoc”:861,“holidayTemp”:22,“tempColor”:4,“deviceId”:437753,“deviceName”:“2 etg”,“roomId”:202303041525049984,“powerStatus”:0,“heaterFlag”:0,“humidity”:54.2,“lock”:0,“deviceType”:3,“humidityCountdownTotalStr”:“00:15”,“isManualControl”:0,“showOpen”:0,“preHeatStatus”:0,“eco2Status”:1,“coolingStatus”:0,“eco2ChargingStr”:“–”,“currentTemp”:15.2,“eco2Color”:3,“humidityStatus”:1,“reportTime”:1699016877287,“humidityColor”:3,“showBusinessLock”:0,“isHoliday”:0,“description”:“”,“tvocCountdownTotalStr”:“72:00”,“humidityChargingStr”:“–.-”,“deviceStatus”:1,“tempCountdownTotalStr”:“00:15”,“tvocChargingStr”:“–”,“times”:“”,“fanStatus”:0,“holidayTemp_dou”:22.0,“tvocStatus”:1,“tvocColor”:3,“tvoc”:77,“fanStatusShow”:0,“showPreHeat”:0,“eco2CountdownTotalStr”:“72:00”,“charging”:0,“electricity”:0.0,“canChangeTemp”:1,“tempChargingStr”:“–.-”,“eco2”:909,“batteryPer”:100.0,“subDomainId”:6933,“tempStatus”:1,“calibrationStatus”:0,“showChildLock”:0,“open”:0},{“maxTvoc”:861,“holidayTemp”:22,“tempColor”:3,“deviceId”:437754,“deviceName”:“kjeller”,“roomId”:202303041525049984,“powerStatus”:0,“heaterFlag”:0,“humidity”:34.7,“lock”:0,“deviceType”:3,“humidityCountdownTotalStr”:“00:15”,“isManualControl”:0,“showOpen”:0,“preHeatStatus”:0,“eco2Status”:1,“coolingStatus”:0,“eco2ChargingStr”:“–”,“currentTemp”:20.9,“eco2Color”:3,“humidityStatus”:1,“reportTime”:1699016730056,“humidityColor”:3,“showBusinessLock”:0,“isHoliday”:0,“description”:“”,“tvocCountdownTotalStr”:“72:00”,“humidityChargingStr”:“–.-”,“deviceStatus”:1,“tempCountdownTotalStr”:“00:15”,“tvocChargingStr”:“–”,“times”:“”,“fanStatus”:0,“holidayTemp_dou”:22.0,“tvocStatus”:1,“tvocColor”:3,“tvoc”:0,“fanStatusShow”:0,“showPreHeat”:0,“eco2CountdownTotalStr”:“72:00”,“charging”:0,“electricity”:0.0,“canChangeTemp”:1,“tempChargingStr”:“–.-”,“eco2”:0,“batteryPer”:100.0,“subDomainId”:6933,“tempStatus”:1,“calibrationStatus”:0,“showChildLock”:0,“open”:0},{“maxTvoc”:861,“holidayTemp”:22,“tempColor”:3,“deviceId”:437758,“deviceName”:“stue”,“roomId”:202303041525049984,“powerStatus”:0,“heaterFlag”:0,“humidity”:37.5,“lock”:0,“deviceType”:3,“humidityCountdownTotalStr”:“00:15”,“isManualControl”:0,“showOpen”:0,“preHeatStatus”:0,“eco2Status”:1,“coolingStatus”:0,“eco2ChargingStr”:“–”,“currentTemp”:20.0,“eco2Color”:3,“humidityStatus”:1,“reportTime”:1699016525163,“humidityColor”:3,“showBusinessLock”:0,“isHoliday”:0,“description”:“”,“tvocCountdownTotalStr”:“72:00”,“humidityChargingStr”:“–.-”,“deviceStatus”:1,“tempCountdownTotalStr”:“00:15”,“tvocChargingStr”:“–”,“times”:“”,“fanStatus”:0,“holidayTemp_dou”:22.0,“tvocStatus”:1,“tvocColor”:3,“tvoc”:57,“fanStatusShow”:0,“showPreHeat”:0,“eco2CountdownTotalStr”:“72:00”,“charging”:0,“electricity”:0.0,“canChangeTemp”:1,“tempChargingStr”:“–.-”,“eco2”:780,“batteryPer”:74.0,“subDomainId”:6933,“tempStatus”:1,“calibrationStatus”:0,“showChildLock”:0,“open”:0}]}
2023-11-23 07:17:06.571 DEBUG (MainThread) [mill] Result {“code”:0,“deviceId”:68169,“deviceName”:null,“valueTotal”:0.0,“allDataFlag”:0,“haveSensor”:1,“haveAir”:1,“percent”:0,“kwh”:{“mode”:0,“startTimeMax”:1700690400000,“endTimeMax”:1700694000000,“startTimeMin”:1700690400000,“endTimeMin”:1700694000000,“valueMax”:0.0,“valueMin”:0.0,“valueNow”:0.0,“chartList”:[{“lostStatisticData”:1,“mode”:0,“value”:0.0,“time”:1700690400000},{“lostStatisticData”:1,“mode”:0,“value”:0.0,“time”:1700694000000},{“lostStatisticData”:1,“mode”:0,“value”:0.0,“time”:1700697600000},{“lostStatisticData”:1,“mode”:0,“value”:0.0,“time”:1700701200000},{“lostStatisticData”:1,“mode”:0,“value”:0.0,“time”:1700704800000},{“lostStatisticData”:1,“mode”:0,“value”:0.0,“time”:1700708400000},{“lostStatisticData”:1,“mode”:0,“value”:0.0,“time”:1700712000000},{“lostStatisticData”:1,“mode”:0,“value”:0.0,“time”:1700715600000}]},“temp”:{“mode”:0,“startTimeMax”:1700690400000,“endTimeMax”:1700694000000,“startTimeMin”:1700690400000,“endTimeMin”:1700694000000,“valueMax”:0.0,“valueMin”:0.0,“valueNow”:0.0,“levelMax”:3,“levelMin”:3,“chartList”:[{“level”:3,“lostStatisticData”:1,“mode”:0,“value”:0.0,“time”:1700690400000},{“level”:3,“lostStatisticData”:1,“mode”:0,“value”:0.0,“time”:1700694000000},{“level”:3,“lostStatisticData”:1,“mode”:0,“value”:0.0,“time”:1700697600000},{“level”:3,“lostStatisticData”:1,“mode”:0,“value”:0.0,“time”:1700701200000},{“level”:3,“lostStatisticData”:1,“mode”:0,“value”:0.0,“time”:1700704800000},{“level”:3,“lostStatisticData”:1,“mode”:0,“value”:0.0,“time”:1700708400000},{“level”:3,“lostStatisticData”:1,“mode”:0,“value”:0.0,“time”:1700712000000},{“level”:3,“lostStatisticData”:1,“mode”:0,“value”:0.0,“time”:1700715600000}]},“humidity”:null,“tvoc”:null,“eco2”:null,“pm”:null}
2023-11-23 07:17:06.573 DEBUG (MainThread) [mill] Result {“code”:0,“deviceId”:68169,“deviceName”:null,“valueTotal”:0.0,“allDataFlag”:0,“haveSensor”:1,“haveAir”:1,“percent”:0,“kwh”:{“mode”:0,“startTimeMax”:1672524000000,“endTimeMax”:1675202400000,“startTimeMin”:1672524000000,“endTimeMin”:1675202400000,“valueMax”:0.0,“valueMin”:0.0,“valueNow”:0.0,“chartList”:[{“lostStatisticData”:1,“mode”:0,“value”:0.0,“time”:1672524000000},{“lostStatisticData”:1,“mode”:0,“value”:0.0,“time”:1675202400000},{“lostStatisticData”:1,“mode”:0,“value”:0.0,“time”:1677621600000},{“lostStatisticData”:1,“mode”:0,“value”:0.0,“time”:1680300000000},{“lostStatisticData”:1,“mode”:0,“value”:0.0,“time”:1682892000000},{“lostStatisticData”:1,“mode”:0,“value”:0.0,“time”:1685570400000},{“lostStatisticData”:1,“mode”:0,“value”:0.0,“time”:1688162400000},{“lostStatisticData”:1,“mode”:0,“value”:0.0,“time”:1690840800000},{“lostStatisticData”:1,“mode”:0,“value”:0.0,“time”:1693519200000},{“lostStatisticData”:1,“mode”:0,“value”:0.0,“time”:1696111200000},{“lostStatisticData”:1,“mode”:0,“value”:0.0,“time”:1698789600000},{“lostStatisticData”:1,“mode”:0,“value”:0.0,“time”:1701381600000}]},“temp”:{“mode”:0,“startTimeMax”:1672524000000,“endTimeMax”:1675202400000,“startTimeMin”:1672524000000,“endTimeMin”:1675202400000,“valueMax”:0.0,“valueMin”:0.0,“valueNow”:0.0,“levelMax”:3,“levelMin”:3,“chartList”:[{“level”:3,“lostStatisticData”:1,“mode”:0,“value”:0.0,“time”:1672524000000},{“level”:3,“lostStatisticData”:1,“mode”:0,“value”:0.0,“time”:1675202400000},{“level”:3,“lostStatisticData”:1,“mode”:0,“value”:0.0,“time”:1677621600000},{“level”:3,“lostStatisticData”:1,“mode”:0,“value”:0.0,“time”:1680300000000},{“level”:3,“lostStatisticData”:1,“mode”:0,“value”:0.0,“time”:1682892000000},{“level”:3,“lostStatisticData”:1,“mode”:0,“value”:0.0,“time”:1685570400000},{“level”:3,“lostStatisticData”:1,“mode”:0,“value”:0.0,“time”:1688162400000},{“level”:3,“lostStatisticData”:1,“mode”:0,“value”:0.0,“time”:1690840800000},{“level”:3,“lostStatisticData”:1,“mode”:0,“value”:0.0,“time”:1693519200000},{“level”:3,“lostStatisticData”:1,“mode”:0,“value”:0.0,“time”:1696111200000},{“level”:3,“lostStatisticData”:1,“mode”:0,“value”:0.0,“time”:1698789600000},{“level”:3,“lostStatisticData”:1,“mode”:0,“value”:0.0,“time”:1701381600000}]},“humidity”:null,“tvoc”:null,“eco2”:null,“pm”:null}
2023-11-23 07:17:06.573 DEBUG (MainThread) [homeassistant.components.mill] Finished fetching mill data in 1.421 seconds (success: True)
2023-11-23 07:17:06.576 DEBUG (MainThread) [mill] SubDomain 5333
2023-11-23 07:17:06.576 DEBUG (MainThread) [mill] SubDomain 5316
2023-11-23 07:17:06.577 DEBUG (MainThread) [mill] SubDomain 5333
2023-11-23 07:17:06.577 DEBUG (MainThread) [mill] SubDomain 5316
So maybe some more info can help someone to see what can be wrong…
I attach the log in case some one will look into it.
What i have notice is…
The log show info witch is the same as the Mill app.
I measn I can see the “same” device names in the logs as in the Mill app.
Hovever the result into HASS is something else.
It seems that HASS is showing some OLD devices and setup, witch is deleted for a long time ago.
Is there any cash about Mill anyplace?
Mill setup shows this…
witch is not the same as the app :frowning:
This log indicates that you do not use the latest version of Home Assistant or a custom component for Mill.
Holy smoke…
that easy.
I upgraded homeassistant (docker) and then everything vent ok.
Tnx Daniel…
