Is there someone who can explain me why can’t I set Mill heater temperature from Home Assistant. Only possibility is to add room temperature which requires room name and does actually nothing.
I have tested to add Mill to room in Mill application but that did not do anything. All that I can do is set HVAC mod to WARM or OFF. That works.
I would love to set temperature by using Home Assistant but seems like I do not understand how it works. I can set temperature manually from Home Assistant dashboard thought.
Thanks, that was it. I had to add mill device again to mill account and after that it seems to be working.
And yeah… did a mistake in first message. I ment to write something like this:
“Is there someone who can explain me why can’t I set Mill heater temperature by using Home Assistant automation rule and command: (Climate: set target temperature).”
