Mill integration: prepping for winter: how to get a useful current_power
follow up from How to calculate energy from this power sensor (why is the output way too low...) - #5 by Mariusthvdb
but now a dedicated search for the power entity. Updated device with new firmware, installed the device in the app, and integrated into the HA integration.
Set it up as local only for obvious reasons.
I can control individually, and see most adapt to the real states, temp, connection etc etc target and current. That is to say, when controlling from HA. When I change settings I the app, the HA integration does Not follow suit, not even after refreshing the pageā€¦
Annoyingly too, the current_power remains on 0, for minutes and minutes after having it started heating.I didnt aut any longer, so it probably never changes.
As this is a power entity, that makes it useless. Cant we fix that in any other way then connecting it over a smart plug?
there is a closed issue https://github.com/home-assistant/core/issues/95424#issuecomment-1705373910
