I’m currently using the Mill integration, and it works pretty well.
However, the only feature i seem to be missing is being able to set power-levels of my gen3 heater itself.
According to the app (and from the buttons on the device itself) I can set three heat-levels; Low, Mid, and High.
I’d like to be able to set these via a service for the mill integration, so I can possibly adjust the heater level programmatically or myself from home assistant, so I don’t need to go back and forth to the app to do it.
(One such integration is to have the heater go into different power level modes depending on how far behind the current sensed temperature is compared to the desired temperature)
