Hello @luka6000 , thanks for the answer.
Do you know, if (and how) I can do that for a single light?
My mii desk pro lamp has: max_color_temp_kelvin: 20000
But it actually has only a value of 4800 as maximum.
I did not find a solution yet with google.
depends on what you’ll customize. If you’ll set it for ‘light’ domain then you’ll have it customized for all lights independently. But light groups (old seen as ‘group.’ and new helpers seen as ‘light.’) will inherit their settings from member lights so you still get min and max for the group the same as for individual lights.
Adding the min max values to the light.(group) does not work correctly. The Group is not adapting the Kelvin values to the mired values are not calculated. If I use the customize_domain: key for all lights it works as expected.
