Min max for temperature Sensor
would it be possible to integrate a min max temperature sensor which shows the min and max value of a single sensor for e.g. the last 24 hours or the last 7 days. Hitorical values should be available as they are shown in the history-graph.
I use that for temperature however, it’s not quite what you want as it won’t for instance give you the minimum/maximum for the current day. You can specify 24 hours but that’s not today.
You could also do that with the custom mini-graph-card. See the examples below.
Hi!
Statistic sensor sounds good. But how can I publish the max value on Lovelace?
