Mini-climate card won't work
Use since years the default climate cards without and problem and want to change to your mini-climate-card as it’s much more flexible (or it should be) and it’s much more compact.
For instance I have a climate in my kitchen:
The entity ID is automatically generated by the Multimatic integration, I know it’s long. Actually it’s climate.keuken_21200500202529220938006781n3 and not without n3 as the picture shows.
The default HA climate card works fine:
I installed your repo by HACS. Restared HA afterwards and started to make my first mini-climate card:
As you see the state on the right always remains ‘Unavailable’
The entity ID is correct entered.
Any idea how to resolve in order to continue?
Any logs to check?
Thanks in advance,
