jdukat
(Jarosław Dukat)
April 14, 2024, 6:42pm
1
I just added Sonos speaker and Mini Media Player to my HA.
It works perfectly from desktop/web interface, but the same dashboard that works on PC with web browser shows this error on Android companion app:
Any clues why?
If that matters, here’s the card configuration, fairly simple:
cards:
- type: custom:mini-media-player
entity: media_player.living_room
group: false
volume_stateless: true
toggle_power: false
artwork: material
shortcuts:
columns: 3
buttons:
- name: Free FM Rock
type: music
- name: AntyRadio
type: music
- name: Radio 357
type: music
source: full
info: scroll
do you see the same issue using chrome for android on the same device? is android system webview upto date?
jdukat
(Jarosław Dukat)
April 14, 2024, 7:06pm
3
Yes, same problem when going to the dashboard from chrome and from firefox on my android device.
What does it mean exactly “is android system webview upto date”?
I have all the available updates installed on my device… Anything I should install or setup manually?
jdukat
(Jarosław Dukat)
April 14, 2024, 7:13pm
4
Just found something interesting.
From my PC I connect to HA over local network address ( http://192.168.0.xxx )
From my Android device I have connection configured over Cloudflared tunnel.
When connected to HA from PC over the tunnel, I saw the same error on the PC.
Connecting from Android to local address doesn’t solve the problem, though.
its an app on your phone that updates via the play store, its like keeping the browser up to date.
since you can reproduce on the browser in the same device you need to check with the custom card author to see if they can help you out.
jdukat
(Jarosław Dukat)
April 14, 2024, 8:42pm
6
Ok, solved the problem following the steps here:
opened 01:55AM - 07 Jan 20 UTC
closed 07:20PM - 07 Jan 20 UTC
I've tried all the solutions I've found so far, to no avail. I keep ge… tting this error. I don't know what else to try!
I have this in the raw config editor:
```resources:
- type: module
url: /community_plugin/mini-media-player/mini-media-player-bundle.js
- type: module
url: /community_plugin/button-card/button-card.js```
I have this in my config.yaml
frontend:
javascript_version: latest`
I have this in my ui-lovelace.yaml and also tried module instead of js for type:
resources:
- url: /local/mini-media-player-bundle.js?v=1.5.1
type: js`
This is in my raw config editor:
entities:
- entity: media_player.bedroom
group: true
hide:
power: true
volume: true
info: short
source: icon
type: 'custom:mini-media-player'
- controls: true
entity: media_player.my_room_speaker
group: true
hide: null
type: entities
Any help is greatly appreciated! Thanks in advance.
Edit: Apparently I can't figure out how to format correctly on this website. Please bear with me. Although my issue doesn't make any note about syntax.
Edit 2: I was unfamiliar with HACS before this, but I just added it. If anybody is able to point me in a direction to add this that way too that would be fine. I can't find it in the integrations list in HACS.
and here (UI mode) - added duplicate mini media player entry in my HA
Now it works everywhere.
Looks like the installation through HACS is not working perfectly.
I’ve filled another issue on github for this.
