So for the last few months thanks to the wonderful works of Steve Looman and his git repo I’ve been able to use my DLNA speakers with HA like a champ. However as part of the process of the pull to make it a main component of HA the work around that was in the custom library was removed. Steve recommended that I setup a MiniDLNA server so that my speakers can stream the files from there, i.e. grandfather clock chimes. Its been a while since I"ve needed a DLNA server and in the past I always just browsed to what I wanted from the client.
So here is the question(s)
- How do you find the path from DLNA to pass to the device?
- I’m hoping that its just a simple http path.
- Can TTS be used in this manner?
Thank you all for your help with this.
