Minimalist-UI Custom:Button-Card , Grid layout
As Mention above please “format code”
And as you are using Custom:Button-Card Template ( Most likely with your button-card-grid defined there, it would be most relevant you also showed this(formatted) ( beside a pic i.e how you’d expect it to look like )
Customizing - UI Lovelace Minimalist.
🌻 Lovelace UI • Minimalist.
PS: I changed Your Header, and Category, to reflect the Dashboard , Card and “issue” you are facing.
You also might be better of Searching in The Big Forum-Topic for this Dashboard “Lovelace UI” above, and post a question in this Topic/Project
The docs for this specific Dashboard you find in the first link above
