Minimalistic Dashboard for Climate
My radiators are managed through Tado valves. I wanted to create a compact, yet usable dashboard to show their status and values. I tried all the climate custom cards I can found on HACS, with no luck. I used the Simple Thermostat Card for a while, but I was not able to show all my radiators on a single page, without scrolling. I use Home Assistant mainly by the smartphone, so the interface should be as compact as possible.
These are the parameters I want to show:
  • current temperature
  • current humidity
  • target temperature
  • on/off status
  • heating/idle status
  • boiler on/off status
I want to be able to set:
  • on/off status
To set the target temperature is not so critical. My automations setup implements defaults for every room, so for the 90% of use I just need to turn the radiator on/off.
So, let’s start by showing you the resulting interface.
As you can see, the interface is so compact that I still have some free space to activate some scenarios.
The target temperature is shown only when the radiator is turned on. The ones currently heating takes the theme accent colour. To set the target temperature, I simply click on the device line and set it through the standard entity interface. It fits my needs.
set target
I was able to create this using a simple Entities card, powered up by the Multiple Entity Row custom card. It was as simple as that.
This is the code of a sample entity.
- type: entities
  entities:
    - type: custom:multiple-entity-row
      entity: climate.cucina
      toggle: true
      state_color: true
      entities:
        - attribute: temperature
          format: precision1
          unit: false
          hide_unavailable: true
          hide_if:
            below: 6
        - attribute: current_humidity
          unit: '%'
        - attribute: current_temperature
          format: precision1
          unit: false
You need to repeat the attributes’ header on every entity, if you want the values to be aligned like a grid.
The boiler entity has a slightly different setup, since it is just there for reference. The main difference is about the tap_action: it does nothing.
- type: entities
  entities:
      entity: climate.termostato
      toggle: false
      state_color: true
      show_state: false
      icon: mdi:fire
      tap_action:
        action: none
Actually, I use the Decluttering custom card to keep the dashboard code clean and readable, but that’s up to you.
Bye!
