Minimote blueprint
I am starting to create blueprints and I am trying to create a blueprint for a zwave minimote by aeon labs. The remote has four button each button generate a scene_value_id for a single press and a different id for a long press.
I have create 8 different automation, one for each state and it works correctly. Since I have 3 of these remotes, I thought that instead of having to create 24 automation, I would create a blueprint for the remote and use it to create different automation based on the blueprint for each remote.
I searched the blueprint exchange and found a blueprint that is similar but for a different zwave remote. original remote
I created the basic blueprint, created an animation based on the blueprint that sends a notification when any of the buttons is pressed. When I test, only the first button is working. I am not sure what I am doing wrong. Any help would be appreciated.
Here is my blueprint
blueprint:
  name: Aeon Labs MiniMote US
  description: Create automations for the Aeon Labs ZWus MiniMote using the OZW
    integration.
  domain: automation
  input:
    aeonlabs_minimote:
      description: List of available Minimote remotes to configure. This list
        is only a reference. At this time, it is not possible to obtain the node's
        id using the device selector.
      selector:
        device:
          integration: ozw
          manufacturer: AEON Labs
          model: DSA03202 Minimote
    ozw_node_id:
      description: Enter the node id for an available NanoMote Quad you wish to configure.
        For now, this field is required. At this time, it is not possible to obtain
        the node's id when using the device selector.
    button_1:
      name: Press Button One
      description: Action to run on button press.
      default: []
      selector:
        action: {}
    button_2:
      name: Press Button Two
      default: []
      selector:
        action: {}
    button_3:
      name: Press Button Three
      default: []
      selector:
        action: {}
    button_4:
      name: Press Button Four
      default: []
      selector:
        action: {}
  # source_url:
mode: single
max_exceeded: silent
variables:
  device_id: !input 'aeonlabs_minimote'
  ozw_node_id: !input 'ozw_node_id'
- platform: event
  event_type: ozw.scene_activated
  event_data:
    scene_value_id: 1
condition: '{{ trigger.event.data.node_id == (ozw_node_id | int) }}'
- variables:
    scene_id: '{{ trigger.event.data.scene_value_id}}'
- choose:
  - conditions: '{{ scene_id == 1 }}'
    sequence: !input 'button_1'
  - conditions: '{{ scene_id == 3 }}'
    sequence: !input 'button_2'
  - conditions: '{{ scene_id == 5 }}'
    sequence: !input 'button_3'
  - conditions: '{{ scene_id == 7 }}'
    sequence: !input 'button_4'
and the created automation
- id: '1609095307452'
  alias: Aeon Labs MiniMote Remote 3
  description: ''
  use_blueprint:
    path: johnny/ozw-aeonlabs-zwus.yaml
    input:
      aeonlabs_minimote: 51fd7c54d4a1ef66706b701acfb474c5
      ozw_node_id: '9'
      button_1:
      - service: notify.notify
          message: test 1
      button_2:
          message: Button 2 test
      button_3:
          message: Button 3 test
      button_4:
          message: button 4 test
Just modified this to work for someone else. Just had to remove the event data from the trigger so that all event data triggers it.
blueprint:
    integration.
  domain: automation
  input:
    aeonlabs_minimote:
      selector:
        device:
          integration: ozw
    ozw_node_id:
    button_1:
      default: []
      selector:
        action: {}
    button_2:
      default: []
      selector:
        action: {}
    button_3:
      default: []
      selector:
        action: {}
    button_4:
      default: []
      selector:
        action: {}
  # source_url:
mode: single
variables:
- platform: event
- variables:
- choose:
This worked perfectly.
Thank you
I created an automation based on this blueprint and in one of the buttons, i call a script that turn a fan on, delay for 2 hour, then turn it off. it seems that the seems ignore any button presses till the 2 hours expire. What do I need to do such that it can still respond to buttons while waiting for the 2 hours.
