I recently had some luck installing Home Assistant OS on a Lenovo M90n IOT machine. 256GB SATA SSD and 4GB memory. I may be deploying this at a remote location so I’m thinking about another Home Assistant OS install at my own house. I have an old HP Mini 210 laptop with 2GB of memory and an SSD installed. I thought I might give that a go because my HA needs are pretty basic. What’s not clear is whether 2GB of memory for a raw Home Assistant OS install is enough? No VM. No Docker. No Promox. No need to share the hardware with anything else.
(I believe this laptop will take a max of 4GB but I won’t bother unless someone tells me it’s necessary.)
