poratnir
(Nir Porat)
May 12, 2018, 6:24am
1
Hey someone was able to integrate minix to work with home assitance?
Sorry you talking about the android box?
If yes, what do you want it to do?
Assuming you want it to open apps, you can use this post
I want to use my home harmony remote to be able to start a specific application (netflix/plex/you tube) on my nvidia shield. It’s not as easy as I thought it would be, so I thought I’d share the process!
Prereq:
Ensure you have mosquitto installed and configured (you also obviously need HASS and a shield!) I talk about integrating with harmony, but you don’t have to do this bit - it’s just what I use to trigger the automatioin.
Part 1:
The first part is getting it so the harmony remote can a…
poratnir
(Nir Porat)
May 12, 2018, 9:38am
3
Stream radio stations and open youtube and so on…
poratnir
(Nir Porat)
May 12, 2018, 9:39am
4
this is for harmony remote , is there any post for minix?
Yes this also works, because tasker is acting as the bridge.
You install tasker and mosquitto in the Minix and the use HA to publish mqtt messages with the instructions.
Just follow the set up
poratnir
(Nir Porat)
May 12, 2018, 6:49pm
6
the guide is not so clear …
is there a simple way to use it?
