Since I updated to 0.88.1 I get this error. After debugging a while with no results, I changed my config to the example from the doc:
automation:
alias: “Exterior Lighting on when dark outside”
platform: numeric_state
entity_id: sun.sun
value_template: “{{ state.attributes.elevation }}”
# Can be a positive or negative number
below: -4.0
service: switch.turn_on
entity_id: switch.exterior_lighting
And I still get this error
Invalid config for [automation]: [minutes] is an invalid option for [automation]. Check: automation->trigger->0->minutes. (See ?, line ?). Please check the docs at https://home-assistant.io/components/automation/ Invalid config for [automation]: [minutes] is an invalid option for [automation]. Check: automation->trigger->0->minutes. (See ?, line ?). Please check the docs at https://home-assistant.io/components/automation/ Invalid config for [automation]: [minutes] is an invalid option for [automation]. Check: automation->trigger->1->minutes. (See ?, line ?). Please check the docs at https://home-assistant.io/components/automation/
