luke2023
(LinChe(Luke)(KSAC LC2716)(林澈))
December 30, 2023, 5:23pm
1
I’m using miot to control my zhimi.fan.fb1 fan . everything works well, except the horizontal and vertical angle control have no response after changing the value
(firmware is latest)
Any one have been able to control this fan?
opened 12:45PM - 15 Dec 23 UTC
### Device model / 设备型号
zhimi.fan.fb1
### Component version / 插件版本
0.7.… 13
### HA core version / HA版本
2023.11.3
### Integrated mode / 集成方式
Automatic (自动模式)
### The problem / 问题详情
### Entity attributes / 实体属性
reset_modes: Natural Wind, Straight Wind
direction: null
oscillating: false
percentage: 40
percentage_step: 20
preset_mode: Straight Wind
model: zhimi.fan.fb1
lan_ip: 192.168.52.19
mac_address: 7C:C2:94:6C:93:BB
entity_class: MiotFanEntity
home_room: 6632506526 Bedroom
miot_type: urn:miot-spec-v2:device:fan:0000A005:zhimi-fb1:1
fan.on: true
fan.fan_level: 2
fan.horizontal_swing: false
fan.vertical_swing: false
fan.horizontal_angle: 50
fan.vertical_angle: 0
fan.mode: 1
fan.status: 1
fan.fault: 0
fan.brightness: 0
fan.alarm: false
custom_service.timing: 0
custom_service.h_swing_back: false
custom_service.v_swing_back: false
stepless_fan_level-5-10: 25
custom_service.country_code: TW
physical_controls_locked: false
state_updater: lan
friendly_name: Fan Fan
supported_features: 15
sub_entities: fan-2.horizontal_swing-3, fan-2.vertical_swing-4, fan-2.alarm-11, fan-2.horizontal_angle-5, fan-2.vertical_angle-6, physical_controls_locked-6.physical_controls_locked-1
### Home Assistant Logs / 系统日志
Get xiaomi message for 6632506526 failed: {'code': 0, 'message': 'ok', 'result': {'messages': None}}
下午8:36:46 – (警告) Xiaomi Miot Auto (自行安裝整合)
Update of switch.tcam_1_200_privacy is taking over 10 seconds
下午8:34:13 – (警告) helpers/entity.py
Setup of select platform tapo_control is taking over 10 seconds.
下午8:33:42 – (警告) 選擇
Setup of light platform tapo_control is taking over 10 seconds.
下午8:33:42 – (警告) 燈光
Platform input_number does not generate unique IDs. ID humidity_target already exists - ignoring input_number.humidity_target
下午8:33:21 – (錯誤) 數字框
