Mirabella Genio Smart Home
Do you mean could flash it?
Not sure if anyone else got it working or not but here is a config that I got to run correctly with the Genio RGBCCT Downlight. If the max_power is above .2 looks like the SM2135 locks up maybe from over-current Iā€™m assuming.
sm2135:
data_pin: GPIO14
clock_pin: GPIO12
output:
  • platform: sm2135
    channel: 0
    max_power: 0.2
  • platform: sm2135
    channel: 1
    max_power: 0.2
  • platform: sm2135
    channel: 2
    max_power: 0.2
  • platform: sm2135
    channel: 3
  • platform: sm2135
    channel: 4
light:
  • platform: rgbww
    red: output_red
    green: output_green
    blue: output_blue
    cold_white: output_white
    warm_white: output_warmwhite
    cold_white_color_temperature: 6500 K
    warm_white_color_temperature: 2700 K
    color_interlock: true
Hi Dave,
If i removed the ESP Chip from the main board it wouldnā€™t flashā€¦ No idea why.
When i put it back on it flashed no worries.
Cheers
I am trying to setup a Mirabella Genio 9W CCT Downlight (I002742). It has been flashed with Tasmota and I have set up mqtt on the device to link to HA server. For some reason all that is coming through to Homeassistant is a value for sensor.tasmota_status. There is no light entity.
I had this downlight setup a couple of years ago on a rpi and it was working without issue. I am trying to set up on a NUC running latest HA software.
Has anyone any ideas on what the issue could be.
Thanks.
Problem solved. Updated firmware from 8.0.2 to latest 11.1.0. Initially got an error message ā€œUpload buffer miscompareā€. Installed the lite firmware version and then full latest version which did not then error.
Got the Genio 1003989 9W RGB+CCT bulb
This no longer comes with an ESP8266, but has a CB3L instead - one of Tuyaā€™s own ā€œmodulesā€ that contains a BK7231N microcontroller.
Fortunately, this can still be flashed over serial using these instructions: https://www.elektroda.com/rtvforum/topic3874289.html
Hey Ryan, Iā€™ve been configuring a similar Genio E14 RGBCCT SM2135 chipped lamp but having an issue getting the white and warm white to work. RGB is fine though. Iā€™m using the same yaml & channels as you posted above.
Question: How many entities do you see for this lamp in the ESPhome integration ?
I see only 1 but expected 2 or 3 (RGB, WW, CW etc).
This is what Iā€™m seeing but the white channels donā€™t activateā€¦
Capture1
and
I could kiss you I swear, I submitted a ticket to ESPHome like 5 months ago hoping to get the clock strobing issue fixed (Iā€™ve got like 14 of these lights) and now I can RGB MY HOUSE FOR NO REASON
Does cold_white and warm_white channels work for your lights ?
Hey mate, Yeah all works as expected for me. Just change the colour temp and off it goesā€¦ Maybe the cool/warm is on different channels with the E14 lamp?
Hahahaha welcome. Just spend a bit of time tweaking as I found even though it worked on the bench when I came back after a while it had gone wonky. My max_power setting was just trial and error to get that.
Thanks for the feedback.
OK, maybe my lamp is defective, there are only 5 (0-4) channels on the chip and three are used for RGB which are working fine. When I slide the colour temp slider from cold to warm direction the RGB leds go out but white/s does not come on (color_interlock: would make RGB drop out).
I wondered if there was a coding bug in the ESPhome SM2135 driver, but now that canā€™t be if yours works.
I will either find another lamp or probe this one with a CRO and see what the W/WW output PWM pins are doing. Trouble is the voltages around the PCB may be lethalā€¦
Yep, Iā€™ve got all full colour range and now RGB, hereā€™s my yaml :slight_smile:
The gamma correct lets me set the lights to 1% at night time
sm2135:
  clock_pin: GPIO12
  data_pin: GPIO14
# Individual outputs
output:
  - platform: sm2135
    channel: 1
    max_power: 0.2
  - platform: sm2135
    channel: 0
    max_power: 0.2
  - platform: sm2135
    channel: 2
    max_power: 0.2
  - platform: sm2135
    channel: 3
  - platform: sm2135
    channel: 4
light:
  - platform: rgbww
    red: output_red
    green: output_green
    blue: output_blue
    # Ensure the light turns on by default if the physical switch is actuated.
    restore_mode: ALWAYS_ON
    gamma_correct: false
For what itā€™s worth the SM2135 issue is tracked in git here.
Thereā€™s also someone else whoā€™s made a fix thatā€™s yet to be merged into the main branch of esphome
Itā€™s an ESPhome issue since Tasmotaā€™s implementation works fine
I was just about to get my downlights installed and started fiddling with them on the bench again. Found that the colour was a bit off. After some trial and error have found the red channel max power at 0.6 seems to be the sweet spot. If I was a betting man I reckon that you need the sum of all max power to equal 1 when added up for the RGB channels. So when you go to ā€œwhiteā€ with all channels on its still only at 1 or 100%.
Just going to throw this out there: Iā€™m working my way through measuring all of the Mirabella Genio lights, to contribute to powercalc.
If you have a few globes to spare, a lamp and a compatible power measurement device, contributions welcome.
Alternatively, if you are AU based and have any unused globes around, happy to do the measurements and mail them back to you.
I havenā€™t purchased a Genio globe since probably 3-4 years. Just wondering if Tuya-convert is still an option or is there some other method you have to use now to flash with tasmota?
did anyone manage to get the Mirabella Genio Wi-Fi 1.4m Pixel LED Corner Light into home assistant?
You may have luck using the new OTA flash method.
It isnā€™t listed as tested but there are other Mirabella devices so itā€™ll likely work, just needs someone to try and confirm.
Iā€™m not willing to flash it (yet), since Iā€™m pretty sure Iā€™ll loose the sound reaction part.
I managed to get it into HA using localtuya, but Iā€™m not sure I got all the IDs right.
