I may have my wires crossed so please dont treat me like an idiot - i might just be going around this the wrong way.
How do I go about mirroring two input numbers?
The concept:
Currently, Im using a single input_number to control the set temp of a climate control (mainly because I can customize my own design of a thermostat card using card-mod and an automation that uses the input_number to set the temp of the climate entity)
However, I have been having a few disagreements with my wife as to WHO changed the temperature of the AC. She insists its not her, so I decided I will create a dashboard for her phone exclusively for her. Its simpler AND has more WAF for her needs, which is different to mine which is more complex and has more detail.
What I need two input_numbers (input_number.number1 which is on dashboard1 and input_number.number2 which is on dashboard2) with the ability to mirror each other, so that if either one of us make the change it mirrors on the others dashboard with the ability to log which dashboard made the change.
We ARE NOT using separate accounts, I have created an Android shortcut for her that goes directly to her dashboard and we are using the same login credentials as each other.
I have tried doing this but only one input_number changes the other (typically input_number.number1) for obvious reasons.
Any Ideas as to how I can get around this would be FANTASTIC.
value_template: "{{ states('input_number.number1') != states('input_number.number2') }}"
value_template: "{{ states('input_number.number2') != states('input_number.number1') }}"
condition: []
- choose:
- conditions:
- condition: trigger
id:
- number1
sequence:
- service: input_number.set_value
data_template:
entity_id: input_number.number2
value: "{{ states('input_number.number1') }}"
- service: python_script.set_state
data_template:
state: Dads dashboard made the change to the Airconditioner
entity_id: sensor.house_logbook
- conditions:
id:
- number2
sequence:
data_template:
entity_id: input_number.number1
value: "{{ states('input_number.number2') }}"
data_template:
state: Wifes dashboard made the change to the Airconditioner
mode: single
