Missing AC Capabilities via Samsung MIM-H04N WiFi Kit (OCF vs Direct)
Hello SmartThings community and protocol geeks :waving_hand:
I need help solving what seems to be a major capability loss in a Samsung multi-split AC setup using the MIM-H04N WiFi Kit.
:gear: Setup:
  • Samsung System A/C (4 indoor units)
  • Controlled via MIM-H04N WiFi Kit
  • Connected to SmartThings Cloud (OCF-based)
  • Each indoor unit appears as a child device
:test_tube: What works:
  • Basic HVAC control (mode, setpoint, fan speed, swing, etc.)
  • Power on/off
  • execute and switch capabilities on the parent (but very limited)
:prohibited: What doesn’t work (but should):
These features are 100% supported when the same AC unit is connected directly via Wi-Fi, but become unavailable when connected through the WiFi Kit:
Feature Works via native Wi-Fi? Works via WiFi Kit?
Beep sound toggle :white_check_mark: Yes (API & UI) :cross_mark: No
Display light toggle :white_check_mark: Yes (Lighting option) :cross_mark: No
Optional modes (sleep, speed, etc.) :white_check_mark: Yes :cross_mark: Some are missing
Air quality options :white_check_mark: (in capabilities) :cross_mark: Missing entirely
OCF execute options :white_check_mark: Limited :cross_mark: Most fail with NOT_FOUND
I’ve tried:
  • SmartThings API (via Postman)
  • SmartThings CLI
  • Advanced Web IDE
  • Multiple execute paths (mode/vs/0, etc.)
  • All known x.com.samsung.da.options
  • Monitoring event logs while pressing “Lighting” or “Beep” on physical IR remote → No events are captured.
Even tried polling capabilities like airConditionerLighting, audioVolume, airConditionerBeep, airConditionerOptionalMode, airConditionerFanOscillation, doNotDisturb, etc. — but none are exposed on the child devices, or on the parent.
:pushpin: Important detail:
  • The same model indoor unit, when connected without the MIM-H04N (i.e. Wi-Fi embedded), exposes all capabilities in SmartThings.
  • So it’s not a model limitation — it’s a firmware/API exposure limitation through the MIM-H04N.
:red_question_mark: My questions:
  1. Is there any hidden execute command or undocumented capability that can trigger these functions?
  2. Has anyone hacked/extended functionality of the MIM-H04N via SmartThings (Edge Driver, OCF, CLI)?
  3. Is there any official roadmap or workaround from Samsung to fix this limitation?
:bullseye: Goal:
Enable full automation and voice control over all features already supported by the device — not just the basics.
Any insights, deep dives, or clever hacks are very welcome. :folded_hands:
I’m happy to share my API logs, device dumps, and test cases.
Thanks in advance to anyone up for the challenge!
News about this issue?
Same place here…
