After a fresh install of HAOS on my Pi 3 B 1.2 i can’t see any Add-ons?
https://github.com/home-assistant/operating-system/releases/download/9.4/haos_rpi3-64-9.4.img.xz
This is the OS version right?
Am i missing something?
Br Johnny
Br Johnny
Hi Johnny,
have you added the community repository ?
Have you installed HACS ?
Neither of those questions matter. He should be seeing official addons in settings → addons, addon on store button.
You’re missing the official addon store, which shouldn’t happen. Give me a moment.
Are you blocking the fallback cloudflare dns server (1.1.1.1)? HA uses that as a fallback when it cannot resolve a DNS. The only way for the community store to fail is that it typically can’t find the dns server or the fallback dns server. You can check your supervisor logs and see if there are any errors about this.
settings → system → logs → upper right dropdown → supervisor logs.
There’s an error above those warnings that will point you to the problem.
How do i check this file? I can’t activate SSH?
In the terminal i don’t really know how to check this file?
You can’t just scroll up?
The only way to access the full file is via SSH, which is an add on.
Outside of that, if this is a fresh install, something definitely went wrong. Did you have internet connection when you set this up?
Sorry, i miss understod you.
I joined the Beta Channel and restarted, and after that it seems to work.
You shouldn’t have to join the beta channel, but either way, it looks like it’s working now. Just leave the beta channel. During setup, you must have had some internet connection issues that didn’t resolve.
I left the Beta Channel and it seems to work after a restart.
Thanks for the fast respons!
